First post, by McBierle
Hi, does anyone have experience with ncftp under dos?
It just hangs after starting ncftp.exe. Numlock still works. Another ftp client works with cwsdpmi, so it seems ncftp is the problem here.
Or alternativly, does anyone know a dos ftp client which supports copying of directory trees?
greetings
mcbierle
Reply 1 of 1, by srmeister
i read in the forums there are some people having problems with NcFTP, as i had myself.
I had problem on my 386 because the version found in the internet needs a math coprocessor.
So i recompiled the sources and here you go, it includes autodetection of math coprocessor and if not available, uses emulation of 387. It is compiled with newest version of DJGPP.
It is configured to use DHCP and you need to run packet driver beforehand.
hope it helps.
