yourepicfailure wrote on 2021-03-26, 05:19:Repaired a T4400C power supply board. Unit powered up, and I get a nice whopping 20 minutes off the battery.
Also swapped the dr […]
Also swapped the drive with a 340mb microdrive and it worked well.
For 3 days.
Then the LCD started acting funny so I looked in there too.
Turns out some SMD electrolytics blew out on the "brain" board. Now waiting for replacements to arrive from mouser to go replace those too.
Luckily didn't get very far onto the actual panel, so shouldn't be too bad of a job.
Hey, I just got a Toshiba with a bad PSU as well! 😀
Mine's a T1950CT, which was reported as shutting off when you tried to turn it on, unless you left it for a few hours. It didn't work at all for me and I didn't wait to find out.
Sure enough inside it, one of the capacitors (the 16v 1000uf Elna cap) had leaked onto the board:
The two other big caps also smelled fishy when heated so they got replaced too. Cleaned the board up thoroughly with IPA:
I was lucky and had each one of these in the same capacitance, voltage & temperature rating. I only replaced those three though, the rest tested okay, were fairly small and had weird values, so I didn't want to wait for replacements.
Maybe I should make a thread about it, I made a note of the capacitors for anyone else having trouble with Toshibas of this vintage. My T4900CT will probably need the same thing done soon.
I was interested to see what the caps looked like on the display since the capacitors look like that on your one. I think this T1950CT is quite low hours actual usage since it's not yellowed, the HD still works, almost all plastics intact and the CCFL is pretty bright. Maybe it will happen in future though. Since my T4900CT clearly had a lot of usage in its day with its yellowed plastics, I Should really check the TFT in there too.
The capacitors look like they're okay for now:
Check out the size of the panel, 8.4" viewable area and all that board around it. While I was in there, fixed up the hinge plastics where two screw posts had snapped off, added some thermoplastic to keep it all in place:
Oh yeah, and I replaced the belt on the floppy drive since I don't want to go back into the laptop again - replacing those Citizen W1D laptop drive belts is the worst! The drive sounds kind of janky now, but it reads disks okay.
