Reply 18780 of 27629, by Jed118
Horun wrote on 2021-04-24, 03:36:
Took my mom (85) to hospital, she fell this morning. All is good no serious damage but could have been. Spent the afternoon re-working her bedroom so is more senior sensitive (with many arguments).
Same thing happened to me last week, same preparations were made around the room.
Glad she's OK 😁
What's for sale? my eBay!
Reply 18781 of 27629, by Joakim
Took my mom (85) to hospital, she fell this morning. All is good no serious damage but could have been. Spent the afternoon re-w […]
After that came home and fired up the old Kenwood KR-8010 (1979) https://www.hifiengine.com/manual_library/ken … d/kr-8010.shtml
fed by Denon DCM-360 (1996) https://www.hifiengine.com/manual_library/den … n/dcm-360.shtml
pushed to some Infinity SM-122 (in Brown wood) towers and played some ACDC and Van Halen to relieve the tension, a few beers did help ;p ....
Went thru my old box of cdroms to add some to this thread: What is a period correct Optical Drive?
Sorry if this in off topic but was a bad day in many ways 🙁
It's tough to get old and tough to see the ones you care for get old. Get her one of those alarm bracelets and consider/plan for regular help if needed. My grandmother really shined up in her last years when she received help. Hope your mom gets well soon.
Reply 18782 of 27629, by Shreddoc
Partway through constructing another amateur MT32-pi build.
Plastic jiffy boxes are annoying to cut neat holes in. From my research, it seems the world agrees on this. That is all.
My sincere best wishes to your mom and yourself, dude.
Reply 18783 of 27629, by Jed118
Hooked up some ridiculous * (edit just figured out there's a W in front of the name) Wave Master 240 speakers to my retro corner:
I couldn't pass these up at the thrift store for $6 - too big to ship with an eBay system, but perfect for the Retro Corner 😁
They sound great, and the power adapter for them is ridiculous - very similar to a C64 brick in size, output power, and DIN plug. I love the aesthetic.
Reply 18784 of 27629, by mwdmeyer
I've done my super socket 7 CPU benchmark review with a new (to me) MVP3 motherboard. K5 vs K6 vs Intel vs Cyrix
https://www.youtube.com/watch?v=Ueo8vfhFeM8
Reply 18785 of 27629, by fool
I started upgrading couple of my 8MB Voodoo2 to 12MB. Same time wondering would 16MB upgrade be possible without ruining everything. Of course it would not make sense other than being cool. I don't even know is there drivers/glide games supporting that memory size (some Obsidans maybe?).
I looked my V2 boards and every one of those has memory chip pin #15 -> N/C.
So to get 512kb x 16b DRAMs to work, pin #15 should be connected to some pin(s) of Bruce(s).
Interestingly PowerColor EvilKing II has DRAM pin #15 connected due to 512kb x 16 chips (single side RAM layout). Otherwise it has the same 3dfx reference layout. Though photos are good at VGAMuseum, by fast analysis I could not track where are those pins #15 connected to. Maybe I'll look this better another time.
http://www.vgamuseum.info/index.php/component … 4-3dfx-voodoo-2
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 18786 of 27629, by twilliamc
I recently replaced most of the fans in my dual socket rig.
1009.36 KiB
1.23 MiB
787.1 KiB
Next on my list will be either completely replacing the power supply or just replacing its fans.
I have been a Lian-Li fan since about 2006 and held on to my original PC-65 case since I bought it. On the left is my newer Lian-Li LANCOOL II Mesh RGB. I am not a huge fan of RGB so they are likely going to be replaced with more Noctua. Here is my old case vs new.
1.35 MiB
Unnamed: 486DX4 @ 120MHz, 16MB, 2GB, 2MB VGA, SBPro 2.0, DOS/W3.11, W95
PC-65:P3 @ 800MHz x2, 512MB, 128GB SSD, Voodoo3, SB Live!, Win98SE
Reply 18787 of 27629, by creepingnet
Been (very slowly) building out the 80GB drives on my machines. The v/50 is pretty much done and going, the 40EC is getting setup currently but I'm having CD-ROM issues so I might be swapping to a more modern CD-ROM soon for these old boxes.
I have an extra drive - trying to decide between a souped up Win98SE setup with WPA for WiFi to share between my P/75 and M/75, or a FreeDOS setup for the M/75 that's just a clone of what's on the P/75.
My personal life is going extra slow right now due to various other things going on so I'm not getting to tweak and tune as much as I'd like.
~The Creeping Network~
Reply 18788 of 27629, by liqmat
Building a new old stock vintage system, at no cost other than shipping, for a friend who's a member here and at VCF. He's looking forward to it.
NOS InWin A500 ATX Computer Case
NOS Supermicro P6DBE Dual Slot 1 Motherboard
NOS Intel Pentium II 300MHz x2
512MB RAM (128MB x 4)
13GB IDE HDD
Sound Blaster 32 w/ 32MB RAM
NOS Intel PRO/100+ PCI Server NIC
AOpen DVD Writer
1.44MB Floppy
The video card is a NOS 1MB S3 Trio64 PCI video card (exp 2MB). He can add his own AGP card if he likes.
Here is the beginnings of it on the InWin A500 pull out mobo tray:
679.65 KiB
446.97 KiB
316.65 KiB
548.75 KiB
Reply 18789 of 27629, by PD2JK
Will it run a multiprocessor OS or is it just for the aesthetics? Either way fabulous!
Green PCBs; clean look. And I like the brass accent on the coolers. Maybe sleeve the CPU fan cables with something black. 😀
Reply 18790 of 27629, by Jed118
liqmat wrote on 2021-04-27, 01:07:
Building a new old stock vintage system, at no cost other than shipping, for a friend who's a member here and at VCF. He's looki […]
NOS In Win A500 ATX Computer Case
13GB IDE HDD
AOpen DVD Writer
1.44MB Floppy
Here is the beginnings of it on the In Win A500 pull out mobo tray:
Is that 72 PIN memory on the sound card?
Reply 18791 of 27629, by H3nrik V!
Nice! And Klamaths even .. That's gonna be a lot of heat 😀
Reply 18792 of 27629, by liqmat
PD2JK wrote on 2021-04-27, 06:37:
Well, I'm leaving the HDD blank, but I think it's a great multiuse dual boot candidate of a machine. A little DOS/Win 3.1 so CPU #1 feels important and a little Win2K so CPU #2 doesn't feel lonely. I wish the brass was my idea, but those CPUs actually came from unused IBM CPU upgrade kits. The HSF was already factory installed and amazingly the thermal compound that is probably fossilized inside is doing its job in spades. I think the colorful electric wire coming from the fans is a nice splash of color, but then again I was never very caught up in vintage hardware interior decorating. 😉 Overall, I agree, I think it looks handsome for sure. Too bad it will be locked away in a case that has no windows, but I love me some InWin A500. One of my favorite vintage beige cases. If it only had a LED readout it would be a killer.
Jed118 wrote on 2021-04-27, 06:38:
No sir. Just your standard 30-pin. On another note, one of the cheap plastic memory clips snapped from age, but the remaining clip is holding it nicely in one of the slots. The entire memory mounting assembly is one piece so Luckybob directed me to a higher quality replacement that has metals clips. I will be shipping that with the system so the new owner can have a weekend project if they so choose.
H3nrik V! wrote on 2021-04-27, 09:35:
Believe it or not they idle at around 36C. Under load they only get into the 50s. The Klamath has a max temp of 72C from what I was reading. Maybe IBM put their secret sauce sandwiched in-between the HSF and CPU. Maybe it's peanut butter. Like I said, I didn't change the paste since they are NOS and the temps look really good. If it aint broke... Which brings up another interesting fact about the Supermicro P6DBE. After applying the last and latest BIOS to the board I went into the settings only to find a wall of text in potions (I mean options). I know it's a workstation/small server board, but it has a lot to contend with in there. I left most of it at default settings. I could not understand why the front 80mm case fan was not kicking in that I had plugged into the board's thermal fan plug. Appears this board has a built-in piezo thermal alarm speaker you can enable in the BIOS and you can set the temp threshold of when it should sound the alarm. According to the manual that is when the 80mm case fan will kick in to cool the system down. So I set the threshold to 33C and holy mama on a torpedo. That was seriously loud and made my wife jump into the ceiling, but hey, it worked and the fan kicked in. I would say that was pretty cool, but that's just me trying to be funny.
Reply 18793 of 27629, by Standard Def Steve
And 86w on the 5v rail just for the CPUs, when they're under maximum load. That's up there in overclocked Athlon XP land! 😜
Reply 18794 of 27629, by kalm_traveler
13GB IDE HDD
AOpen DVD Writer
1.44MB Floppy
Hi there - which PSU are you planning to use with that?
I have a dual Pentium III 1.4ghz Tyan board that I was trying to use but it seems like two Pentium III's need a very high amount of amps on the +5v rail and I haven't been able to track down a totally working PSU with enough grunt for it.
As for me, last night I finally managed to get the single rig more or less Windows 98SE stable, got Win2k installed and mostly stable so far. Seems that DIMM 1 slot maybe isn't happy so instead of 512mb RAM (256, 128, 128) I'm only running the 128mb sticks in slots 2 and 3 for now. Had some issues with the 'newest' reference drivers for the Vortex 2 sound card but one version back works great. Currently investigating a possible graphics card issue that seems to be mostly related to low color depth but at the end of the night in Win2k I started getting some artifacting even at 32-bit and native screen resolution so it may be some kind of hardware issue/failure.
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:i9 10980XE, 64gb DDR4, 2x Titan RTX | i9 9900KS, 32gb DDR4, RTX 2080 Ti | '19 Razer Blade Pro
Reply 18795 of 27629, by douglar
224.85 KiB
I finally got the all the face plates to match on the white tower and a dark gray tower case that I've had since 1998.
3d printed the CF plate and the USB plate. They were black gloss, but they match the tower pretty well after taking the sine off with some fine grit sand paper.
Reply 18796 of 27629, by liqmat
douglar wrote on 2021-04-27, 18:05:
I have found with those late 90s Gateway cases the power buttons love to break and sink inside. It's the way they are angled and the plastic poles on either side of the power button gets plastic fatigue and tends to snap over time. There was a guy selling 3D printed power button replicas on Ebay for awhile and I bought a handful from him. No longer have the machine so the extra power buttons went with it. I posted about it awhile ago. Might be something to consider as a 3D print project down the road.
Reply 18797 of 27629, by PC@LIVE
Yesterday I upgraded the PCChips M549.
Unfortunately the 512KB L2 cache has a problem and I have to disable it.
Having the switching regulators, I have no problems with the temperatures of the mosfets, going up in frequency.
I changed the CPU, removed the P.133 and put a K6-2-400 (2.2V).
The minimum Vcore that can be set by the jumpers is however 2.5V, I proceed and start the MB.
It boots but the CPU is not recognized by the BIOS, it is identified as -MMX 66MHz, any frequency use.
The K6-2 is a CXT, so the 2X setting is automatically remapped to 6X.
I tried three FSB 55 60 and 66 frequencies, corresponding to 330 360 and 400MHz.
Having W95 as the OS, at 400MHz it doesn't start, while at 360 and 330 it does.
For this problem I have to find a special file that solves the problem.
The rest of the configuration is: 64MB RAM, VGA CL-5446 2MB, SB Vibra16S, IBM 10/100 PCI LAN.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 18798 of 27629, by brostenen
Watching some Demo's on Black Bessy. My homebuild SixtyClone 250466....
154.91 KiB
135 KiB
97.59 KiB
Reply 18799 of 27629, by appiah4
There is this inverted OEM AT PC case that I am very fond of, and I built my Pentium 133 inside as a semi-restoration (the box is badged Multima 133, so a Pentium 133 with a sound card and CD-ROM along with a Voodoo card sounded appropriate). It has a three digit speed display but it was running on a small 1.5V battery which completely leaked and destroyed much of the traces on the PCB. I removed that, and I will be desoldering the segment display to look underneath, find where the battery connects, and solder on some dupont cables, so I can hook it up to an AA battery holder.
First things first though, I removed the dead power LED from the front panel and replaced it with a new one.
Tomorrow I will begin repairing the speed display.
