Reply 39401 of 53040, by Miphee
Ydee wrote on 2021-06-09, 09:54:
Challenge and lottery, I understand:) I have it similarly.
That feeling when you fix a broken hardware and test it for the first time and.. it works!
It's the best.
Reply 39402 of 53040, by BitWrangler
Fresh from the average user broken stuff is best, large proportion is actually functional, just misconfigured or something. If you get to know of a shop where they part swap until things works, dive their dumpster, the first two things they took out weren't the problem, so only one in three parts in there is actually bad 🤣
Reply 39403 of 53040, by Salient
Yes, bought another SC-155 for cheap. It really did need some TLC though but the result is nice.
See the before and after shots 😀
ps: fixed the power button as well as it was somewhat broken.
Reply 39405 of 53040, by Miphee
BitWrangler wrote on 2021-06-09, 12:47:
Exactly. Many sellers don't bother to check if it's missing a jumper or a chip, just sell them AS-IS. I'm not complaining though. 😁
Just got a socket 7 board that had the jumpers all messed up and the seller sold it as not working since he couldn't get it to work. Those are the sweetest deals.
Reply 39406 of 53040, by wiretap
Received my new-in-box InWin IW-V500T today (mATX mid-tower). Looks great and is ready for a retro build. PSU has a nice 5V rail, but I'll have to bench check it and take a look at the caps first.
My Github
Circuit Board Repair Manuals
Reply 39407 of 53040, by cyclone3d
Miphee wrote on 2021-06-09, 19:28:
Nice. The motherboard in my current computer was sold for cheap because of bent / damaged pins in the CPU socket. Highest end ASUS workstation board for LGA 2011-3 and I got it for $100. Have a couple other LGA 2011-3 boards that didn't have near as much damage to the socket pins as this one. I actually had to McGuyver a new pin into place on this one from a replacement socket I bought from China.
I also really love getting retro/vintage hardware sold as-is and then it is either a super simple fix or it works like brand new from the get-go.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 39408 of 53040, by Intel486dx33
wiretap wrote on 2021-06-09, 19:36:
Received my new-in-box InWin IW-V500T today (mATX mid-tower). Looks great and is ready for a retro build. PSU has a nice 5V rail […]
I had one of those in the 1990’s
It was very popular because of its clean look and it was inexpensive.
Probably under $50 but I don’t remember exactly how much it costs.
I still have one in my garage.
But I really don’t like the internals. Its not as well thought out like the Lian Li cases.
Reply 39409 of 53040, by Timecop1983
I bought a set of cards today. Two are Riva TNT (Gainward & STB Velocity 4400) for sure, but I don't know what the third is. Please can you help to identify it by photo?
Reply 39411 of 53040, by Miphee
cyclone3d wrote on 2021-06-09, 19:44:
This could be a nice debate. Which one is better: pins on the mainboard or pins on the CPU?
I love that the CPUs got less sensitive, no more damaged pins!
Boards are more rare though so I don't know.
Reply 39413 of 53040, by cyclone3d
Miphee wrote on 2021-06-09, 21:02:
This could be a nice debate. Which one is better: pins on the mainboard or pins on the CPU? I love that the CPUs got less sensit […]
Older CPUs with less / thicker pins are better as pinned CPUs.
Newer stuff is better with pins in the socket. The newer pinned AMD CPUs are a nightmare to straighten pins on. It is also pretty easy to pull the CPU out with the cooler with pinned CPUs.
LGA CPUs/sockets completely eliminate the issue of being able to pull the CPU out of the socket when removing the cooler.
YMF7x4 Guide
Reply 39414 of 53040, by Pierre32
Salient wrote on 2021-06-09, 17:43:
Beautiful job!
Reply 39415 of 53040, by Caluser2000
This arrived today. Realtek chipset so absolutely nt problem any old '90s OS. nz$5 plus postage.
Reply 39416 of 53040, by AngryByDefault
Down the rabbit hole, step 1 ...
270.26 KiB
Just arrived!...
Finding a mainboard for building my theme system is proving impossible so far, but as these are becoming more rare and I got them for a good price i figured I'd get them before they're gone...
Now I have to keep diggin' for a board and every other piece 😜
Reply 39417 of 53040, by BitWrangler
ADZ has higher temperature rating I think, how long will it take 7 volts on LN2 though? 🤣
Reply 39418 of 53040, by AngryByDefault
BitWrangler wrote on 2021-06-09, 23:26:
yeap, I got that one to tinker and push it and the other one to "treasure it" 😜
Surely nothing spectacular around here, but hey, it was my first retro-purchase!
Reply 39419 of 53040, by PcBytes
These came in yesterday at lunch.
ASUS P2B, P2 400 SL3EE, Matrox G200, 40GB WDC.
Paid about $34 total.
