First post, by Vaudane
All going well I will soon be receiving a new-old-stock piece of hardware with all manuals and installation disks. On all me searches online I have never found mention of either of these beyond they exist so it wouldn't be a stretch to say these may be the last in existence.
For the 3.5" disks I have a Linux machine with a floppy drive I can just use dd on, but the only system I have a 5.25" drive on is my 386. What would be the best approach here?
Also, with the manuals,how do I go about getting a high quality scan for archiving purposes?
Reply 1 of 14, by TheMobRules
For disk imaging under DOS environments I highly recommend M. Brutman's DskImage. It's a very simple utility, but it's fast, produces exact copies of the original disk and can retry reading failed sectors.
I would avoid stuff such as WinImage as the image produced is not identical to the original as it writes its own stuff to the boot sector. Also, if at some point you use Windows 9x, make sure your original disks are write protected as Windows will modify the boot sector by just accessing the disk.
Reply 2 of 14, by Horun
For manual scans I use my Iphone and take pictures then use PaintShop Pro and edit/size them, then import into Acrobat Pro for a .PDF. I have a scanner but it is quicker/easier to just take pictures of the pages.
Not the best solution but it works....
Reply 3 of 14, by BitWrangler
If you're gonna do a bit of this sort of thing, you might want to make a simple book scanning rig, something along the lines of https://hackaday.com/2011/07/18/diy-book-scan … -600-pageshour/ which basically is, something to hold the camera in position, good lighting, and glass to press the page down so you get a pic of it flat and straight.
However, you might find that if you're just getting booklets that are simply stapled and of A5 size, then pulling the staple and putting them through a sheet feed scanner at an office supply store or print shop is real easy, or setting up your own flatbed, AIO printer etc. Some people even go as far as guillotining off a glued up spine to use a sheet feeder.
Reply 4 of 14, by Pierre32
Horun wrote on 2021-07-06, 22:55:
On my Android phone I use the Microsoft Lens app. Generates PDFs directly so you can skip the PC step!
Reply 5 of 14, by Jo22
Yay! This method reminds me of all these old spy films. James Bond would be jealous. 😁
Let's turn these snap shots into micro film, and I'd be perfect!
Edit: But if you insist using PDF, please have a look at PDF/A. 😀
https://en.wikipedia.org/wiki/PDF/A
Reply 6 of 14, by Joseph_Joestar
Taking pictures from a phone is ok for something you need done quick, but I wouldn't recommend it for proper document archival. The angles at which you take photos won't be the same every time which can result in uneven page alignment.
Best to use a scanner for that purpose.
My retro builds
Reply 7 of 14, by Pierre32
Joseph_Joestar wrote on 2021-07-07, 07:33:
A scanner is certainly the best option - but if you don't have the hardware, the output of MS Lens is very impressive (perspective correction, easy cropping, OCR etc).
https://support.microsoft.com/en-us/office/mi … af-b5874a8e6f2b
Jo22 wrote on 2021-07-07, 07:07:
Yay! This method reminds me of all these old spy films. James Bond would be jealous. :D […]
This information is new to me! Good to know.
Reply 8 of 14, by Vaudane
Thanks for the information guys! I don't know what form the manual will be in, if its a thick book, booklets bound by arch lever, or stapled books but these are all good methods to know.
TheMobRules wrote on 2021-07-06, 19:47:
Exactly what I was after thanks. And TIL about windows messing with the boot sector. I've ordered a CF card so I can run a DOS environment that I can swap out easily with other machines and read out the images.
Reply 9 of 14, by Deksor
This only happens when you create a new image with winimage 😀
But imaging disks on windows isn't a great idea because even windows tends to mess with the files on the disk. What I'd recommend to op, whatever you do, write-lock your disks to avoid any program messing with your disk !
Reply 10 of 14, by Mister Xiado
For stapled manuals, a flatbed scanner is fine, but for bound manuals, perhaps a proper book scanner. They're specialized equipment that prevents excessive spine damage to books, as you only need to open them to about 90º to scan two facing pages.
Reply 11 of 14, by Jo22
Deksor wrote on 2021-07-09, 15:48:
I second that. Especially Windows 9x is a beast when it comes to mess up floppies.
http://www.os2museum.com/wp/the-ihc-damage/
That's why I use either Windows 3.1/WinImage 3 or a modern Windows.
Write-lock.. It's important to remember that it works in reverse on 5,25" diskettes:
To enable write-protection, a little label must be attached to the floppy's write protection notch.
Many people get that wrong, like the
librarians of my local library.
A single Windows 95/98 PC is enough to destroy history. 😟
Reply 12 of 14, by Caluser2000
Jo22 wrote on 2021-07-10, 21:25:
I second that. Especially Windows 9x is a beast when it comes to mess up floppies. […]
Why? You can just shell out tp MS Dos 7.x and use that.
ttps://www.disk-image.com/screen_dos.htm here is one and there have been a ton of others over the years that don't require any version of MS Windows. The simtel archives have a crap load of the iirc.
Is that copy of Win3.1 Winimage been licensed and payed for prey tell?
Reply 13 of 14, by Horun
I use Winimage 7 under XP for nearly all my 720k/1.44m floppies images. Have used DCP and a few others (older raread/rawrite, etc) on the 486 for work on 360k floppies.
Reply 14 of 14, by Jo22
Caluser2000 wrote on 2021-07-10, 21:48:
Because.
