First post, by lackofpatience
I have a question about CPU Voltages. usually I can figure it out but not sure on this one.
I've got the following AMD K6 socket 7 CPU (not a K6-2). It shows the following voltages on the chip.
When checking the CPU world link it shows many voltages at the bottom of the page. But looking at my motherboard info, I don't think it supports such voltages (despite supporting various K6 and K6-2 CPU's)
Am I right in saying my motherboard will fry the cpu due to not having matching voltage numbers? More info in the links,
Cheers! 😀
CPU info:
https://www.cpu-world.com/CPUs/K6/AMD-K6%2026 … -K6-266AFR.html
Motherboard info:
https://stason.org/TULARC/pc/motherboards/B/B … Pentiu-205.html
    18.3 KiB
    The motherboard I'm using
    1.56 MiB
    CPU
    15.83 KiB
    CPU Voltage
Reply 2 of 4, by lackofpatience
quicknick wrote on 2021-07-28, 00:00:
If your board is the Biostar MB-8500TTD you're in luck:
mb-8500ttd manual needed
Ahh yes! I did find that after doing some more googling, I will give it a try and see what happens haha
Reply 3 of 4, by BitWrangler
In general though, the K6s and K6-2s of 2.2 to 2.4V will tolerate 2.5V under a decent sized heatsink and 2.7V under something gargantuan with a copper slug or a waterblock. (In the second case, the lifetime might only be a year or two)
edit: Conversely, I put a 2.4V K6-2 on a board that had some very odd voltage choices back in the day, think it had 2.6, 2.7, 2.8 annnd 2.3, 2.6 seemed like it was gonna be a little hot, so I stuck it on 2.3 and it ran fine, would only overclock about 25mhz though, but knowing it would even overclock a little was comforting that it wasn't gonna be edge-casey at stock speed on those volts.
Reply 4 of 4, by The Serpent Rider
Nonsense. 2.8v is absolutely fine for K6-2 and does not require anything but decently sized aluminum cooler. Now 3.3v is a different story...
