First post, by InbetweenDays
I have a serial + PS/2 compatible mouse that I use on my test bench, and wanted to get a spare because it's so useful. It's a Microsoft wheel mouse - the spares I picked up today are the MS Basic ones (no wheel). Interestingly they worked fine with the PS/2 port, but not with the PS/2 to serial adapter. Since neither worked, I decided to check the adapter.
I have three adapters and was using the green one:
Checking the pinouts, the green one looks like this (looking into the female PS/2 connector; numbered by the DE9 connector pins)
Which corresponds to this diagram found online:
The dark grey (middle) one has this pinout:
Which corresponds to this image found online:
Now the important point: The MS Wheel mouse works with both the green and dark grey adapters. The MS Basic mouse only works with the dark grey adapter.
Hopefully this saves someone a bit of time, or saves some hardware from being binned!
It don't mean a thing if it ain't got 5-pin DIN.
Roland addict and founding member of the Association Of Molex Haters
Reply 1 of 5, by InbetweenDays
By the way, the light grey adapter has this pinout:
It doesn't work at all, which isn't surprising since only 3 pins are connected. I guess it's for some other system and/or faulty.
Has anyone seen this type before?
Reply 3 of 5, by weedeewee
InbetweenDays wrote on 2021-07-30, 09:59:
By the way, the light grey adapter has this pinout: pinout3.jpg […]
is the shield still connected and maybe connected to some pin ?
Do not ask Why !
Reply 4 of 5, by InbetweenDays
1541 wrote on 2021-07-30, 11:22:
For PS/2 mice that do not support the serial protocol anymore, you'll need a more sophisticated solution:
PS/2 to Microsoft Serialmouse Adapter Converter / Updated First Post / Firmware Update added
Yes, I know... or the easier solution in such cases is probably just to have both PS/2 and serial mice... 😀
Reply 5 of 5, by InbetweenDays
weedeewee wrote on 2021-07-30, 11:55:
hmm good point, I should have checked that... tomorrow maybe!
