Reply 40180 of 56754, by BitWrangler
I would guess that it would tend to make your hand black from the silver oxide if you used it, then green when it started wearing down to the copper (Frequently the base layer under EP silver)
Reply 40181 of 56754, by Law212
spiroyster wrote on 2021-08-20, 15:25:
Law212 wrote on 2021-08-20, 15:20:
spiroyster wrote on 2021-08-20, 15:08:
They come up on ebay uk quite regularly, they are silver plated ... I've seen them branded and non-branded... always that PS/2 L […]
They come up on ebay uk quite regularly, they are silver plated ... I've seen them branded and non-branded... always that PS/2 Logitec mouse.
Here's one now... (https://www.ebay.co.uk/itm/154554995758?hash= … -0AAOSw2Zde~upb).. obviously not my auction 😀. [EDIT: search "Wallace Mouse"... more than one on both ebay UK and US].
In your first photo, looking at the gap next to the mouse button, you can see the layer of plating on top of the regular beige plastic. Only plated, so probably not worth stamping with hallmarks.
I think this was (and still is) a popular past time for some Jewellers, although I think in this case this is/was an actual range for custom promo swag as I can see them for various other companies PMC, IBM and non-branded. I have a 24K USB drive somewhere for birthday a while ago customised by a goldsmith, only 2 gig so very dated now... case worth more than the chips probably these days... or not given current climate, so this still goes on.
Thanks, Thats neat, i wish I had that slipcover. Its a cool looking mouse that im going to keep and display. Thanks for the info.
Yeah it's a cool looking mouse. Good to see someone on Vogons get one in the flesh. Probably for display, I bet it's a fingerprint-magnet and if you're anything like me, my OCD wouldn't settle if I was using that mouse regularly... or I would get a mouse mat that could double up as a polishing cloth. 😀
Yeah theres no way id use it because id be polishing it every two seconds
Reply 40182 of 56754, by chrismeyer6
Wallace Silversmiths is a very good company. Me and my wife inherited alot of silverware and serving platers from her grandmother. And all the pieces are probably 70+ years old and still look like new. So odds are that mouse has a seriously high quality silver finish. I'd personally get it polished and display it.
Reply 40183 of 56754, by cyclone3d
retrogamerguy1997 wrote on 2021-08-20, 14:31:
The Asus A7M266 I ordered arrived in the mail today. The cpu cooler appears to have two different connections leading out of it […]
The Asus A7M266 I ordered arrived in the mail today. The cpu cooler appears to have two different connections leading out of it and they were connected when I unwrapped the board. there seemed to be writing on the white one but it isn't readable. I need to now figure out what graphics card to put in. The only agp cards I have is the rage 128 pro and diamond media viper v550. I also have a geforce4 mx4000 pci card.
Pretty sure that that cooler has dual fans in it. That is why there are two connectors.
Those Orb coolers were pretty crappy cooling-wise when they were on the market.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 40184 of 56754, by retrogamerguy1997
cyclone3d wrote on 2021-08-20, 16:24:
yeah I some other people I asked seemed to believe it had dual fans as well, but that doesn't explain the electrical tapes on all the wires on the longer cable.
Reply 40185 of 56754, by cyclone3d
retrogamerguy1997 wrote on 2021-08-20, 16:26:
Looks like somebody took the extra connectors off.
It does have dual fans. See here for a review:
https://www.neoseeker.com/Articles/Hardware/R … s/minisuperorb/
YMF7x4 Guide
Reply 40186 of 56754, by BitWrangler
They were and they weren't. Obviously the design spoke to people who wanted a cool cooler, rather than a cool cooler. When they came out in the socket 370 celeron overclocking boom, they offered competitive performance, also versions for the Slot As and the early Durons were okay in that particular time, but there quickly got to be much better options around, so they were obsolete pretty quickly, but the early reputation fueled demand enough to keep them on the market past their best before date.
Edit: Personally I'd use them on ~900Mhz and below, just to give an idea, while the shorter 1st gens, I'd keep on 700mhz and below. I wouldn't necessarily "choose" them, but a working cooler is a working cooler.
Reply 40187 of 56754, by Law212
chrismeyer6 wrote on 2021-08-20, 16:04:
Cool INfo. Thanks. I probably will do that.
Reply 40188 of 56754, by cyclone3d
BitWrangler wrote on 2021-08-20, 16:38:
I was working at a computer store when they came out. The thin-fin regular style coolers beat them performance-wise very easily.
They did beat the super crappy coolers but I'm not sure that is much of an accomplishment.
The design of the orbs is actually really horrible from a cooling standpoint. There is no way a design like that can effectively remove heat from the CPU. The path to the fins it too far and the fins are way too thick to dissipate heat efficiently.
YMF7x4 Guide
Reply 40189 of 56754, by BitWrangler
If you'll remember that time though, coolers very seldom had much of a name, maybe a part number, so if you walked into most stores and asked for a CPU cooler for X, you got the crappy generic one, just having a name, and awareness meant you knew an orb was better than low end, so you knew what you were getting. I'd agree though, they needed more thinner and shorter fins really. There were zalman coolers that nailed it later.
Reply 40190 of 56754, by cyclone3d
Yep. The Zalman fan style and the round style was good as well.
My favorite from that time period before the heatpipe coolers came out is the standard design but with thin fins and copper heatspreader ones made by Antec.
Around that time I had tried pretty much everything I could get my hands on. For Slot-A I even had one of those super expensive Alpha coolers with the dual 6k rpm 60mm fans.
That cooler was a piece of trash as well. It soaked up the heat and then couldn't dissipate it.
YMF7x4 Guide
Reply 40191 of 56754, by DonutKing
I picked up a Roland Sound Canvas 8820
The attachment 20210820_232144.jpg is no longer available
This is one of the latest models of Sound Canvas. It supports SC55, SC88, SC88 Pro and a native 8820 instrument mapping.
I used to have an SC55 mk2 which I regrettably sold years ago. The Sc8820 is much smaller, and although it lacks the LCD screen and buttons of its older brothers, I wouldn't know what to do with those anyway. I never touched them when I owned an SC55.
The SC8820 also has a USB interface. I was surprised to find that Roland has drivers on its website. Although the latest drivers are for Vista x64 they work perfectly in windows 10. If you run it over USB you also don't need to plug in an AC adapter, which is nifty.
Getting it working in Dosbox over USB was easy, simply had to run mixer /listmidi which told me the ID number of the SC8820, then editing the Dosbox config, set mididevice=coremidi and midiconfig=1 which was the ID number of the SC8820 PART A listed in the previous command.
I made a couple of recordings:
Rise of the Triad - Havana Smooth - SC55 mode
Doom e1m1 - SC55 mode
To my untrained ear, in SC55 mode it sounds exactly like a real SC55, at least compared to recordings I found on youtube.
I feel like SC88 mode is a little bit nicer sounding:
Rise of the Triad - Havana Smooth - SC88 mode
Doom e1m1 - SC88 mode
The only downside is that it doesnt have an MT32 instrument mapping. This means that Monkey Island, for example, sounds a bit odd. Not a big problem for me, as I have an LAPC-I already.
Overall I'm pretty happy with it 😀
Reply 40192 of 56754, by BetaC
Well, I picked up a cute little Yamaha card earlier.
The attachment 65995B3C-8825-428B-A0A8-69980C7BF899.jpeg is no longer available
Yeah, an actually Yamaha branded YMF-724.
Reply 40193 of 56754, by Joakim
BetaC wrote on 2021-08-21, 00:29:
How is it? I am curious if it is a viable OPL alternative my ISA lacking rig. Even if it already has 3 soundcards atm...
Reply 40194 of 56754, by BetaC
Joakim wrote on 2021-08-21, 05:23:
I can't give you an answer on that, really. I don't have any way to sblink.
Reply 40195 of 56754, by bearking
Today's flea market find, for about 7 Euros/8 USD...
The attachment 20210821_090527.jpg is no longer available
Gigabyte GA-6VXDC7 rev 5.0 in like new condition, sealed in its electrostatic bag, but with a little bit of damage.
Four retention clips from the RAM slots are broken, but I have them.
Hope it works...
Reply 40196 of 56754, by DeiwosN
It's no Model M (or so a cursory googling of the product number told me) but I picked myself up a neat IBM KB-7993 keyboard today. It feels great, and only cost $20. Previously I was using some old mushy-keyed Windows XP media thing keyboard I found while I looked for something better, and this is definitely the something better I was after.
The most important thing, to me at least, is that the layout is essentially identical to my main PC's keyboard. The shape and location of a bunch of keys on the old one I was using really messed me up a lot. But it's also solid and the keys feel good to press.
Reply 40197 of 56754, by BitWrangler
bearking wrote on 2021-08-21, 06:32:
Today's flea market find, for about 7 Euros/8 USD... […]
Hope it works...
That's amazing. Though bargains like that cost you a couple of hundred to make the most out of them 🤣
Reply 40198 of 56754, by liqmat
BitWrangler wrote on 2021-08-21, 13:21:
I don't know what friends you have, but most people I know in this hobby have their Smaug piles they pull from when they find a cool new part. 🤣
Reply 40199 of 56754, by Caluser2000
liqmat wrote on 2021-08-21, 14:45:
Sounds painful.Can you get a cream for it from the pharmacy?
