First post, by Namrok
Part 1: Assessment and Mistakes
So this board I ordered in the frigid winter of 2020. It showed up totally dead and unresponsive. It had many obviously leaking capacitors. The guy on ebay just gave me a full refund and didn't even want it back. I threw it in the closet intending to use it to practice soldering at some point.
That point is now! I bought a house in the country, with a detached workshop. I could finally get out the soldering pen I ordered off Amazon and start dicking around. After fixing a children's string of blinky lights, building a clock kit, and fixing an overly complicated toaster's LEDs, I moved onto the Socket 939 motherboard with leaky caps. I also upgraded to a nicer Hakko soldering station. What a difference better tools make.
Step one was assessing if the state of the board had changed at all. I got everything hooked back up on my test bench, and wouldn't you know it, it actually POSTed! I mean, it still needed a lot of capacitors replaced because they were leaking so badly. But wow, an actual sign of life this time. Except at some point the chipset fan had burnt out, and dude had just replaced it with a big bulky thing that blocked the AGP slot. So I find a replacement on ebay, and begin trying to remove it.
The fan comes off no problem. The heatsink however is glued on solid. I try garroting it off with some dental floss to no effect. I try gently heating the glue with a hot air gun, once again to no effect. Then I did something stupid. I used a flat head screw driver to pry it off.
In my defense, I'd had a long day potty training and cleaning poop off the floor. So I'd been drinking. Also, it was a little dark, and I couldn't even see there were traces in that section of the board. Also I'm embarrassed because I knew it was a bad idea even as I was doing it, but I did it anyways.
The good news is I got the heatsink off without also lifting the chip off. The bad news is I had gouged the motherboard and damaged the traces.
After scraping off the solder mask, I saw I had 7 damaged traces.
To see just how bad the damage is, I hook everything back up, and see if it has any signs of life. Well, I get one long beep and two short beeps. Which if I interpret correctly means it can no longer interface with the graphics card. So that's pretty bad. I wanted this to be a practice board. I just had no idea I'd be practicing trace repair too! There is always a first time for everything.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
