First post, by Madao
Hello people
I got a XT Clone from dumpster diving.
Their full height MFM hard disk is wreid.
It came from National (Panasonic) , but i couldn't get info about this harddisk.
Have someone information about this cute piece?
regards
Matt
    415.03 KiB
    380.78 KiB
    544.64 KiB
Reply 1 of 12, by Horun
Good find ! Hope the motherboard and floppies work ! Sorry can help on the Hard drive.
Can you pull the cards out and take a good picture of the motherboard ?
If mine I would ditch that HD as the main case is damaged by fall/drop/kicked so the HD most likely will not work anyway. Back then they were glass/ceramic platters and very fragile.
Reply 2 of 12, by BitWrangler
Basic info 1/3 the way down the page here, page 182 in the pdf if it don't take you straight there...
https://archive.org/details/bitsavers_fujitsu … e/n182/mode/2up
Edit: heh, should mention you're looking for Matsushiti on the left
Reply 3 of 12, by Madao
Thanks. ! It is a 10MB MFM (probably a RLL-harddisk, because C 160 H 6 S26 = 12,77MB unformatted capacity)
I know: Matsushita is other old name from panasonic.
Yes, i haven't many hope for harddisk because: Someone has bent case out and put it back and trown it to pile of metal scrap.
XT Clone is produced in 1985, Motherboard look like "self soldered " with many old TTL from 1970s (data code)
Reply 4 of 12, by ODwilly
Nice find!
Reply 5 of 12, by Madao
Horun wrote on 2021-08-27, 02:42:
It is self build XT clone board.
It runs
Reply 6 of 12, by Madao
Next good message:
Harddisk is survived, no damage, no bad track & sector. (excuse me, i use orginal IBM DOS 3.3 german , Pic show you: 8Meg on drive and same count is avaible. )
CRAZY !
(Ok, i have formatted it with MFM and not RLL )
https://youtu.be/4poYkAxZjYo
    189.95 KiB
Reply 7 of 12, by BitWrangler
I guess it might have been properly parked before it was tossed around. Two auto parking utils here if you haven't got a specific one ... http://annex.retroarchive.org/cdrom/nightowl- … 028A/index.html
Reply 8 of 12, by dormcat
BitWrangler wrote on 2021-08-27, 03:02:
I wonder why the table has listed the company as "Matsushiti"
The English title was Matsushita Communication Industrial Co., Ltd.
Reply 10 of 12, by BitWrangler
dormcat wrote on 2021-08-30, 17:55:
No idea, but it appears consistent throughout the publication. If it went through another language than English first, maybe they phoneticised it differently.
Reply 11 of 12, by BitWrangler
Madao wrote on 2021-08-30, 17:56:
@BitWrangler
I have a problem: Landingszone ist unkown.
But thanks for link for autoparking.
The highest cylinder plus 1 is the commonest landing zone location I have seen, but some use -1 or 0 I think.
