First post, by Robin4
- l33t
I set up a 850MB hard drive on a 386 40 mhz motherboard. (the motherboard is a Contaq 386 / 486 one a puchased some years ago.
I can setup the hard drive in the bios with the following geometry:
Size: 849 Cyls: 1646 Head: 16 Precomp: 65535 Lzone: 1645 Sector: 63 Mode: Normal (there is no way to set it up on Large or LBA because 386 motherboards dont have them. So this is what i used.
I thought maybe it could used the full size of the disk. ( i know of the 504MB limitation) But it couldnt.
Do i need a later version of FDISK to do so??
Have installed ms-dos version 6.22 on it.. But there is also no way to make a extended partition for the remainder 300MB which should be usable.
Dont want to install a overlay software.
If there is no other way please tell me..
