Reply 40400 of 58438, by ODwilly
I know with my 770 a dead cmos makee it throw up about 4 error codes and prevents it from booting
Reply 40401 of 58438, by Wolfus
Pierre32 wrote on 2021-09-04, 07:47:
Picked these two up together, as the only bidder. I wanted the ARK, and the Cirrus was just extra weight in the package. When they arrived I took the opportunity to benchmark my small collection of PCI cards, and to my surprise the Cirrus is nipping right at the ARK's heels. So that's the two quickest 2D cards I have now (according to the venerable PierreMark). Pretty happy for a fiver!
Did you popuate empty memory sockets of Cirrus before the test? If I remember correctly, it should significantly boost performance (something with 32/64 bit bus).
Reply 40402 of 58438, by SteveC
EvieSigma wrote on 2021-09-08, 01:33:
I finally got this ThinkPad "iSeries" (Type 2621) after *twelve days* spent mostly lost in transit, can't figure out why it won't POST. The only thing I can think of is that it somehow NEEDS a working CMOS battery to boot? I've already cleaned the RAM and the RAM slots, and since the CPU is soldered I can't really clean that with the equipment I have. The fact that I hear the hard drive kick on but nothing else happens just makes it more confusing.
From my experience with ThinkPads a flat CMOS battery won't stop it booting to at least the BIOS screen - you'll just get 161 and 163 errors that you may not be able to get past.
I have an iSeries ThinkPad too and it's the worst ThinkPad I own - the plastic is so brittle I dare not touch it!
Reply 40403 of 58438, by EvieSigma
SteveC wrote on 2021-09-08, 09:53:
Yeah, after further testing I think there might be a blown fuse in there somewhere, since there doesn't seem to be 5V coming off the USB port on the back.
Reply 40404 of 58438, by RandomStranger
So, while building my recent PII PC, I was thinking that maybe the Ensoniq AudioPCI should be replaced with something more decent. Since it already had a Sound Blaster Vibra 16S I thought maybe something different, so I started looking for Yamaha XG cards. Last weekend I found a YMF724F-V for 3 times the price I was willing to pay, BUT as part of a bundle of sound cards. Today they arrived.
Now I don't intend to keep all of them. The YMF724 naturally stays, I'll keep the Audigy 2 as well, but what about the rest?
Which is better? The CT4530 or the SB0060?
The CT5803 seems to be just another rebranded AudioPCI I already have some.
The SB0570 as far as I know is too mutilated to be of any use.
As for the rest, I don't know if any of them worth keeping over the other SB Live!.
Reply 40405 of 58438, by cyclone3d
The FM801 and ESS Solo-1 cards have DOS support.
The FM801 cards are kind of hit and miss depending on the design. Some have much better output than others.
I would test them all and see which ones you like.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 40406 of 58438, by Joseph_Joestar
RandomStranger wrote on 2021-09-08, 15:41:
The SB0060 has 5.1 functionality. I don't think the CT4830 does.
Also, SB0060 has the CD SPDIF header populated, while the CT4830 does not.
My retro builds
Reply 40407 of 58438, by dionb
Found what was starting to look like a unicorn:
The attachment 16311229663391.jpg is no longer available
The attachment 16311229573120.jpg is no longer available
A 16b PCMCIA WiFi adapter with Prism-II/Orinoco chipset, so DOS support. Sealed and unused.
Of course I still need to find an ISA-PCMCIA card (I should have one somewhere deep in a box), and this thing does max 802.11b with WEP, so slow and insecure as hell. But with some good config on my router (VLAN) and AP I can mitigate that and get a DOS system online wirelessly 😀
cyclone3d wrote on 2021-09-08, 16:07:
I'd be optimistic about the Genius card, it looks like better quality than most FM801.
Also note that the Terratec Solo-1 (the ESS Solo-1 card) has unpopulated wavetable header holes. Solder pins in there and you can add daughterboards (yes, done it on exactly this card, dead easy and nothing more required than those pins).
Reply 40408 of 58438, by Wolfus
My GM collection is getting bigger. SC88, MU50 and GMega arrived today. Hooray for testing 😀
Reply 40409 of 58438, by SteveC
Picked up a new old stock IBM ThinkPad expansion bay for Ultraslimbay devices off eBay - works a treat! Simple and rather inexpensive way of getting a CD ROM drive onto a laptop that doesn't have one.
Did a quick video - https://youtu.be/Yaki_m_3N8c
Reply 40410 of 58438, by ODwilly
Dell QuietKey ps/2 keyboard that looks brand new for $5. Should pair up with my P4 machine really well with a beige ps/2 MS mouse 😁
The attachment IMG_20210908_142300307_HDR.jpg is no longer available
Reply 40411 of 58438, by Pierre32
Wolfus wrote on 2021-09-08, 09:28:
Nope, I haven't filled the slots in any of my cards. The reading I'd done suggested there wasn't much benefit for DOS VGA gaming, and it was more of a benefit for higher resolutions in Windows.
Still kinda keen to do it though. I just need to learn which memory to get.
Reply 40412 of 58438, by Wolfus
Pierre32 wrote on 2021-09-08, 22:22:
Re: What vga is best: S3 trio 64v+ or Cirrus Logic 5436
Also:
Ram chips for S3 virge\trio
These are suitable also for CL and I think for Legend too.
Reply 40413 of 58438, by Pierre32
Wolfus wrote on 2021-09-08, 22:32:
Re: What vga is best: S3 trio 64v+ or Cirrus Logic 5436 […]
Also:
Good links, cheers 😀
Reply 40414 of 58438, by debs3759
Also:
Bookmarked the SOJ chips in that link, thanks. I see they still have loads, so will buy a few lots next time I'm on a spending spree (got lots of cards needing a few different memory types, and it'll be good to upgrade them all before I thin out my collection).
Reply 40415 of 58438, by bearking
Got this combo locally yesterday for a fair price
Gigabyte GA-8TX-C rev 1.0 with a Pentium 4 SL57V @1.7GHz
The attachment 20210908_221919.jpg is no longer available
The attachment 20210908_194958.jpg is no longer available
Unfortunately I couldn't test the board, probably because of the RIMM modules I used. In every configuration I tried, the board wouldn't POST, just gives me three long beeps... I'll try to source 4 identical RIMM modules, but it won't be easy 🙁
Also, I don't have a dedicated P4 power supply, so I used the Antec pictured below. It doesn't have the auxiliary AT style power connector. Maybe I could DIY a cable if necessary.
Also I will need to recap the board, the 3300 microFarad caps are bad...
Reply 40416 of 58438, by gerry
bearking wrote on 2021-09-09, 07:08:
Got this combo locally yesterday for a fair price […]
looks like the makings of a nice windows xp setup or similar, if you have a place to put it plus other components etc
Reply 40417 of 58438, by bearking
gerry wrote on 2021-09-09, 07:45:
Components I have, with space I have a serious issue 😀
Reply 40418 of 58438, by Munx
I have a few boards with one and none of them require it. A socket 423 board among them too. Works with current ATX PSUs just fine.
My builds!
The Underdog - The budget K6
Reply 40419 of 58438, by bearking
Munx wrote on 2021-09-09, 08:14:
Thanks for the info, that's how I remembered...
