Reply 20 of 30, by WhiteFalcon
- Member
zyga64 wrote on 2024-04-16, 17:30:Motherboard from auction site looks like Shuttle HOT-419: https://theretroweb.com/motherboards/s/shuttl … hot-419-ver.1.1 TheRet […]
TheRetroWeb provides BIOS image for it, so there a chance that it is newer than yours (note inside archive says: "5/96 - Latest AMI-Bios 419AIP06.BIN for HOT419DZ")There is also MrBIOS for Jetway J-403TG, which is based on the same chipset (OPTI 82C895): https://theretroweb.com/motherboards/s/jetway … 403tg-v2.0#bios
So if you have access to flash/eprom burner and spare W27C512-45 chip - you can find out for yourself if it makes any difference 😀
Good find, yes, I believe its that one exactly! I will check out the version of the BIOS, although I am very scared of flashing such an old piece of hardware. If something goes wrong, I am totally screwed. The PC works great except for the CF incompatibility which is not a given the newer BIOS would improve. Oh and no, I dont have an eprom programmer, or I have a simple one, but not really any idea how to use it. To risky for my blood 😀
Olivetti M4 P75, 32MB RAM, 4GB HDD, 8GB CF, CD-ROM, SoundBlaster AWE 64, Gravis Ultrasound MAX, Roland SCC-1, Roland MT-32, Roland CM-64
Intel 486DX2/66Mhz, 16MB RAM, VGA Trident 512kB, 1.6GB HDD WD, CD-ROM, 256MB CF, SoundBlaster 16 Pro (CT2910)
