Reply 20 of 28, by leonardo
- Oldbie
Does ADDA still exist?
[Install Win95 like you were born in 1985!] on systems like this or this.
No, it’s not unheard of for stuff like this to last that long without maintenance, this overheating thing is a real problem. That if overcome, could extend life out that far.
The inverters on this site were comissioned in the late 90’s originally and are functional to this day without recap. 24-7-365 operation. Trace SW can’t beat em.
Over the top design: Heat pipes on massive cooling blocks as 1st line buffers, heat transfer to some larger liquid tank as secondary buffer - you have cooler nights I assume, when you can get rid of the heat outside...unless you also need to hide the heat signature, then instead dig down & find an underwater aquifer to cool it. No moving parts, but you still need to protect for overheating when other electronics fail.
demiurge wrote on 2024-05-13, 23:07:In the nuclear industry we have lots of experience with things that have to work 99.99999% of the time. When that cannot be achieved, we build in redundancy. If I was the engineer I would have to build in a parallel supply fan that could be automagically put online if the other's tachometer read below spec. You might want to consider looking at the MTTF specifications to determine your engineering outcomes.
My personal experience with Delta fans are that they move air like mad and are loud because of it.
The standard is for two back to back fans designed to push enough air even with back pressure from one fan being seized. Fan monitoring is to allow for graceful shutdown if cooling fails.
Thanks ! A Very interesting topic. Wish I could add something
added: oh wait I can: Intel used lots of Delta fans in their retail boxed heatsinks plus their after market, many are still working 10-15 later....so yes Delta
Papst metal frame seem to go forever. Comair-Rotron are also brutes, and have models specifically designed for nasty environments.
I have a 21 year old Panasonic Panaflo 80mm in my Athlon XP system. I can say with some level of confidence that it has experienced more "on" time than the vast majority of desktop PCs of that age since I (and others) have used this PC pretty much consistently since I built it back in 2003.
There are probably plenty of fans that can run like this, but I figured I'd put in my 2 cents. 😀
Also, Nidec seem very reliable. And I have a Sunon that is 30 years old and still works (though hasn't been used much in the past 15). Delta can be good, but I have also seen some of their cheaper, smaller fans be complete garbage. YS Tech seems to make decent small fans though.
2 more cents: As others have said, this seems like a somewhat poorly designed device since it has no fan or temperature monitoring despite the high risk and cost of overheating. Without seeing it, I doubt we can offer too much help, but I feel like using larger, more reliable industrial fans mounted externally to pipe air through the system via tubes\ducts would be a good alternative to having tons of tiny fans that were never meant to run in such an environment.
I forgot Comair Rotron.
leonardo wrote on 2024-05-14, 17:25:Does ADDA still exist?
I think they do, but my only experience with them is replacing them after they fail. For some reason, almost all of the Adda fans I've seen were sleeve bearing.
lti wrote on 2024-05-15, 04:26:I forgot Comair Rotron.
I think they were Sunon or Delta equivalent up to mid 90s then went all "race to the bottom" as far as what I've found, old old ones, still plugging away, medium old ones, as you say you find them because you're replacing them.
