Reply 20 of 20, by Jorpho
Jorpho
Offline
- l33t++
wrote:wrote:wrote:Yes it kill your resources and have high cpu usage
Those Mini USB 802.11n = WinModen there bad idea on low end system and you as need USB 2.0 Port and drivers.Um, doesn't "WinModem" kind of imply a modem and not a NIC?
http://en.wikipedia.org/wiki/SoftmodemWhat I getting at is the software perform the entire emulation of a hardware on the main CPU just like a WinModem dose.
A WinModem involves software processing of a digitally-converted audio signal provided by the hardware. What analogous process happens with a NIC?
(The typical NIC really doesn't have much circuity at all on it these days.)
