ARK Logic ARK1000VL VLB video card
Reply 20 of 29, by Skyscraper
kixs wrote:
Not sure what these drivers are. Can get them to work/install under Win 3.1 - maybe for NT. I tried installing ARK2000 drivers a […]
elianda wrote:
Not sure what these drivers are. Can get them to work/install under Win 3.1 - maybe for NT. I tried installing ARK2000 drivers and they install OK. Even look right, but there are glitches.
Finally found the drivers that work:
http://driverzone.com/drivers/paradise/bali32/
Good to know! 😀
*downloading*
Reply 21 of 29, by elianda
You shouldn't be so unflexible, if you go up a folder there are drivers for win9x etc.
You didn't wrote which drivers exactly you were looking for.
Youtube Channel
Reply 22 of 29, by kixs
Rest assured I looked around the FTP - in the upper folder there are actually drivers for ARK2000 - they even work to some level.
The whole thread is only about ARK1000 and Win 3.1 drivers.
But than again I did find about Bali32 because that ARK2000 drivers on the FTP are for Bali64. To some degree I'm quite flexible 😉
Reply 23 of 29, by elianda
ok i'll update the ARK folder then.
edit: There are also the Hercules Stingray Pro, Stingray Pro/Video, Stingray 64 and Stingray 64/Video. Hercules has a Win9x driver with version 4.60b which might be a very late version (it has DirectX2 support).
Youtube Channel
Reply 24 of 29, by CoffeeOne
Anonymous Coward wrote on 2012-02-04, 18:38:
http://www.mmnt.net/db/0/0/ftp.octek.com.au/S … 64__VLVGA1000_V
Try downloading the 3.1/95 drivers for the VL VGA 1000 card at the bottom and see if they work for you.
Hi, I know this thread is very old.
I have the Octek VL-VGA-1000 VER.B card (ARK1000VL chip)
Do you still have the drivers? I am searching for an alternative Win9x driver than the one stored on Vogonsdrivers.
Reply 25 of 29, by CoffeeOne
CoffeeOne wrote on 2023-02-19, 11:26:
Hi, I know this thread is very old. I have the Octek VL-VGA-1000 VER.B card (ARK1000VL chip) Do you still have the drivers? I am […]
UPDATE: Now using the newest driver downloaded from retronn.de. Seems to be good.
Reply 27 of 29, by 386_junkie
kixs wrote on 2016-02-25, 19:24:
Can anyone upload the drivers to here?
Thanks
Reply 28 of 29, by kixs
386_junkie wrote on 2023-12-21, 22:14:
Thanks
Here you go.
ARK Logic Windows 95 Display Driver Version 1.07
