Lukeno94 wrote:LunarG wrote:Meant to write 2G of course...
EDIT: Also, I've not seen youtube mobile default to 144p at any point while having a mobile phone capable of playing youtube videos.
At my parent's place, I struggle to get a 3G signal, so it's not necessarily anything to do with how much money you have, and far more to do with what your area actually provides. Let's not forget that there are areas of the UK where you barely get ANY mobile signal, even now!
I realize that some areas have lesser mobile signal. I just normally don't use internet on my phone when I'm in areas with such poor signal. The question then would be... Do those areas lack broadband, and would you normally use a 486 to watch that 144p youtube stream at about 8fps?
Youtube and 486s are of of such different eras of computing history that it's pretty irrelevant whether it's possible to play youtube on the 486. It can play 90's scene demos, which is much more relevant and usually more rewarding to watch on such a system.
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
