Reply 20 of 26, by AzzKickr
- Member
wrote:While that is a thing that can happen, I already tried all the tricks in the other thread I linked to. I very strongly believe […]
wrote:My money is on the installer programs not being written correctly. When the programmers wrote the install routine they chose an integer that wasn't large enough or the correct signedness (or both).
While that is a thing that can happen, I already tried all the tricks in the other thread I linked to. I very strongly believe that the installer is producing the wrong error message.
Running a genuine Live! card under W2K.
What model number are you using, specifically?
Well I can confirm that it is not a hard drive size issue. Even on a small partition I get the same errors. Formatted my system just to test it. It really is not W2K and above compatible.
I'm using the SB0060, Live! Platinum.
The problem lies in the setup.ins files, containing install settings. I was able to install the whole package with a setup.ins file from a package that does install. But almost no programs work. The ones that do work, like the launcher and the EAX demos refuse to launch when a newer Win2K driver is installed.
Heresy grows from idleness ...
