Reply 20 of 22, by jesolo
- l33t
wrote:To answer the questions of why SP3 and what services/processes I'm talking about, let me take a step back. This PC was a "daily driver" in the early 2000's. So it got all the latest updates etc.. including SP3 and new versions of IE back in the day. It was never rebuilt as a lean retro machine. It's just a survivor.
Just to check if my understanding is correct, you've never rebuilt this machine for the past 13 years or so?
If that is the case, then I'm not surprised of this machine's slow performance. The registry probably contains a number of unused entries of programs you've long since removed and you might still have processes running for apps that weren't properly uninstalled (you might even have some adware/malware lurking around in there as well).
I suggest you perform a fresh installation. You should then see a considerable improvement in performance.
