Reply 20 of 25, by Timecop1983
- Newbie
wrote:You don't need third party drivers to use flash drives in Windows 98. The default Microsoft driver works fine, you just have to insert the Windows 98 installation cd when it ask you for drivers and it'll find it there.
In my case it is not a software issue. I have installed the Windows XP on the same machine and the USB stick behave the same. On the other machine (witch USB2.0/3.0) the stick is working just fine. So I believe it is just incompatibility of my (new) USB stick with (old) USB ports on motherboard 🙁
