Reply 20 of 28, by Tetrium
- l33t++
wrote:wrote:wrote:Also, I might be wrong, but almost all 32MB SDRAM sticks are PC-100 or PC-133, so you can't really go wrong there.
Actually most of 32MB SDRAM sticks were rated @66MHz. I'll refrain from stating that 133MHz 32MB modules don't even exist in case I'm totally wrong with this, but I was working in the field at that time and they were certainly not common.
I'm pretty sure they exist and they are definitely not common, most were PC-66 with 16 chips (2 each side).
Most PC-100 ones (and faster) had like 4 chips on the DIMM, either 2 on each side or all 4 on a single side (and usually turned around 90 degrees compared to the PC-66 DIMMs)
edit: I started doubting if I was correct about the PC-133 32MB modules, so I've been diving into boxes of memory modules and online spec sheets.
I do not have a PC-133 marked 32MB module, but at best have a couple 32MB PC-100 cl2 modules.
4 chips on 1 side (other side empty), DIMM sticker: MT4LSDT464AG-10EB2 PC-100-222-620 and it's an OEM module.
The markings on 1 of the chips (the other 3 are covered by stickers) reads:
48LC4M16A2
TC or TG -8E B
So at best it might be overclockable to 133MHz. I still think it's possible that some freak PC-133 32MB module was created, but these should be made when these modules were already low-end, possibly made with stashes of leftover SDRAM chips rated at 133MHz.
These 2 modules I found were both identical and were HP modules, no idea if these would actually be able to run stable at 133MHz, but afaik PC-100 cl2 might run at 133MHz cl3...or it might not.
edit2: I did find an example of a SDRAM DIMM with a whopping total of 16MB 🤣
