Power supply gurus, help and advice needed
Reply 20 of 22, by tayyare
SirNickity wrote:
Hard to tell from a single picture, but there does seem to be quite a dark dust bunny growing around the heat sink next to where the cables exit. It's also the caps under that bundle of wire that usually fail, in my experience. I haven't seen the mains caps (large ones on the other side) fail myself -- though I'm sure it happens. They take a lot of abuse.
I've had the display driver issue twice before. Once when I had a card that was on its way to the grave, and another time when I just had some buggy drivers. So it could be either of those. If your GPU fan is clogged with the same drier lint and tar combination that's collecting in that PSU, it might need a hit or two from the ol' can of air. 😀
Well, I need to check more closely I guess 😊 I will clean it and check the caps underside.
It's not tar, though. Although I'm a smoker, my home is strictly a no smoking place. 😀
I have the new power supply now, but I like that one too, and it could be utilized with a less power hungry system. If it is salvagable, of course I'd like to keep it.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 21 of 22, by SirNickity
🤣 - I was being sarcastic. It looked like a crossbreed of drier lint and ROOFING tar. 😀
Reply 22 of 22, by tayyare
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
