Reply 20 of 35, by dionb
- l33t++
Xs1nX wrote on 2020-05-24, 16:19:[...] […]
Installed the DOS/Win3.1 Drivers by running the setup.exe in the directory "P16II-1" extracted from the zip by the same name in the Vogons Aztec zip
The resulting installed config utility can not find the sound card, but the "fmtest.exe 220 " command in the same directory does work ? i.e it makes music.
IRQ 5 is reserved in BIOS.
Have been trying to get this working for a while and honestly am about to give up again.. I seem to remember this took hours to get working the last time I had it even half working but I cant remeber how I got it working.
Are you working under native DOS or Windows?
And exactly which Aztech card is it? Best way to look that up is to check the FCC-ID. It contains something like "MMSN824" or similar. That 824 is the card ID. Check here for the marketing names for cards: https://ilovepa.ws/2017/06/08/aztech-sound-cards/
Get your environment (native DOS) and an exact ID of your card sorted and this should be easy. It only gets complicated if you need to start guessing.
