Definitely. These are ancient and vulnerable beasts, being able to see it works well and will still do so once you get home (assuming you don't drop it yourself) is a massive benefit. No point in getting that absolutely sublime monitor for someone to put it unpadded in a cardboard box and arrive in pieces.
Just as an exercise I had a look at what I could get here locally:
- 16 CRTs in the widest sense of the word
- 1 not PC monitor but some security thing
- 5 untested and no obvious redeeming features to make it worth a look
- 1 tested but peeling coating and generally poor condition
So that leaves 9 potential options.
- 2 good looking screens but EUR 250 asking price/bidding (CTX VL-700 17", ForMac ProNitron 21/700 21"). I certainly wouldn't pay those numbers, let's say my max budget would be EUR 200 (in fact I'd aim for max 1/4 that).
7 left. Now, look at the brands:
- Iiyama (2x)
- Samsung
- Dell
- Compaq
- IBM
- Smile
Minimal googling would tell even someone with no prior knowledge, that Smile was a bottom-scraping low end vendor with bad reputation. IBM, Compaq and Dell were OEMs with everything from excellent high-end to low end crap, Samsung was a decent vendor and Iiyama was a premium brand.
Going one step further, the IBM is an E-series, so low-end, as is the Compaq V-series. The Dell though is a P-series (Ultrascan P990) high-end screen. The Samsung is also a decent late CRT screen (SyncMaster 997df) where one Iiyama is an older MF-8617T Vision Master 17 and the other a newer A901HT Vision Master Pro 450.
Then finally google reviews of those specific monitors:
- Dell Ultrascan P990: excellent 0.25 dot pitch, 1600x1200@85Hz 19", not-quite-flat Trinitron
- Iiyama MF-8617T: 1997 model, 1280x1024@80Hz 17", flat-screen aperture-grille tube with good reviews in paper magazines...
- Iiyama A901HT: 1999 model 1600x1200 19" Diamondtron flat-screen tube
- Samsung SyncMaster 997df: very late (2004?) 19" 0.20 dot pitch, 1600x1200@76Hz, flat-screen shadow mask
Now, just looking at those four you can have good discussions on which is best. What is "best" depends on what you want. For Windows desktop work, high refresh rates at high resolutions are key. For Windows gaming on a P2, you need good deep colour and maybe a bit of shadow mask blurring. For DOS, you really want that shadow mask and refresh rates and resolutions beyond 720x400@70Hz aren't interesting in the slightest (so much so that for a pure DOS system I'd look at those low-end IBM or Compaq screens, they would actually look better than this lot). I'd personally prefer a CRT that is not completely flat and doesn't have aperture-grille (diamondtron/trinitron) as that combination tends to make the image look very similar to TFT, which is the whole thing we're trying to avoid here 😉
If I didn't already have a nice 17" Iiyama Vision master (and an old OEM beast that needs repair but would look so much better under DOS) I'd probably start looking at the Dell, then the Samsung and finaly new then old Iiyama - but none is a perfect fit for my preferences and all would be perfectly serviceable.
Obviously it helps that I'm pretty familiar with this stuff, but all the looking up what is available locally, then ditching untested or overpriced options and listing a shortlist of brand + model name of available, affordable and as far as can be judged from a pic: working screens is something anybody could - and should - do.
