Another PS/2 Mouse ISA (ISA8) card adapter
Reply 260 of 334, by maxtherabbit
aries-mu wrote on 2023-11-12, 11:27:
Also, I was wondering, what if on such old PCs one actually connects the PS/2 mouse (instead of the keyboard) to the 5-DIN connector via a simple 5-DIN to PS/2 adapter
would not work at all
Reply 262 of 334, by aries-mu
maxtherabbit wrote on 2023-11-12, 13:57:
too bad!
copper wrote on 2023-11-12, 15:14:
Upping this. Any news?
Apologies, I still intend to do this but got very busy with work for a while.
Oh no need to apologize. Take all the time you need. I understand what it means when life gets (has it ever been different?) crazy insane... just wanted to know if it was still planned...
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
"physical media trumps cloud-simp servitude" (Conrad Riker)
Computers should be fun inside not outside! 😉 (by Joakim, VOGONS)
Reply 263 of 334, by Vulturius
Hi,
Is this card still available for purchase?
Vulturius
Reply 264 of 334, by analog_programmer
rasz_pl wrote on 2023-09-26, 14:16:
This ISA card is two things. PS2 to serial converter, and a Serial 8250 ISA card. It looks great and is a neatly designed all in […]
This ISA card is two things. PS2 to serial converter, and a Serial 8250 ISA card. It looks great and is a neatly designed all in one package. But if you arent after aesthetics and just want a working mouse and already have one serial port available in your computer then $10 will get you there without dedicated card:
https://github.com/LimeProgramming/USB-serial-mouse-adapter for USB mice
USB to Serial Mouse using the Pi Pico! https://dosreloaded.de/forum/thread/5044-usb- … -pico/?pageNo=1
Or as you already have a COM1/2 equipped old mobo/system, just try the one and only user-sensible "blaster"-ish project form this YT-channel: https://www.youtube.com/watch?v=elgyVhlFi6k
P.S. I'm not a fan of this channel and actually I don't find any sense in all the horizontal/vertical/diagonal/north-east/etc. battery "blasters" and so on, but the USB-2-serial mouse seems interesting project (if it works). And how can it be more than remarkable project, if the channel's owner has more than remarkable no-flux-soldering skills... complete tragedy.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 265 of 334, by feipoa
Did anyone eventually pickup the ISA serial emulator card builds?
Reply 266 of 334, by copper
feipoa wrote on 2024-01-20, 02:13:
Hoping to start working on it this week but don't know how long it will take.
Reply 267 of 334, by feipoa
copper wrote on 2024-01-20, 02:28:
Do you have the 3D printed 90-degree brackets and the hole-stamped slot cover?
Reply 268 of 334, by copper
feipoa wrote on 2024-01-20, 04:13:
Do you have the 3D printed 90-degree brackets and the hold-stamped slot cover?
I am looking into some ways to simplify the bracket situation.
Reply 270 of 334, by copper
Sphere478 wrote on 2024-01-21, 01:40:
calamitylime made a pcb based rear bracket
No need for that, I think the options are:
  • Put a motherboard-style PS2 header on the card, and include an off-the-shelf bracket with PS2 port and cable. The bracket would not be attached to the card PCB, but maybe this is useful for some people with limited rear panel space.
  • Have new metal brackets fabricated; I have a recommendation for a place to do it, but don't know cost or minimum quantity yet
Thoughts?
Reply 271 of 334, by AndrewBoy
I'm interested in this project. I have plenty of rigs that cannot handle ps2 and plan to use a KVM switch. Do you know if this ps2 converter would work with an ATEN KVM switch? I need at least 8 PCB-s, SMD is not a problem. I'm in Hungary, so sending the final products to Europe should not cost more than 10 EUR. Does anyone care to join me, and share the gerbers, bom, and firmware?
Reply 272 of 334, by Yoghoo
AndrewBoy wrote on 2024-05-08, 05:26:
Don't think this project is open source so no gerber/firmware etc are available as far as I know. I believe because of sanctions for Russia it's not available atm.
This is working great with an ATEN KVM as I have several myself (and would like more 😀). Do not buy a replacement like the PS2TOSERIAL from Serdashop. It does not work and no replies/help for this issue are given on this forum when I posted about it in that dedicated topic.
Reply 273 of 334, by Sphere478
Yoghoo wrote on 2024-05-08, 08:12:
Re: Another PS/2 Mouse ISA (ISA8) card adapter
Sphere's PCB projects.
Reply 274 of 334, by snipe3687
are there gerber files for this posted somewhere? seems pretty useful.
Reply 275 of 334, by Sphere478
snipe3687 wrote on 2024-05-08, 14:57:
Reply above yours
Reply 278 of 334, by AndrewBoy
Guys, thank you! Can you help me out with the firmware too?
Reply 279 of 334, by Proto-Schlock
Hi everybody,
I'm motivated to build a small batch of these cards if others are still interested and can loan their individual expertise. I can assemble the boards and fabricate the brackets if needed. I have limited experience flashing chips, but could probably figure it out if need be. I don't have the firmware. I'm a noob still and don't think I have the ability to ask Rio444 for his firmware.
I know There are a lot of other DIY solutions available but Rio444's is certainly the most elegant and, from what I've read, works the best.
I may end up building some necroware adapters too, but I still think a straight ISA card is cooler 😀
