Reply 43 of 46, by Stiletto
Great work on the interview! 😁
do the Fandango!" - Queen
Stiletto
Reply 44 of 46, by subhuman@xgtx
will the same happen with a p166 mmx?? or is socket 7 a bit more compatible than p3?
Reply 45 of 46, by idspispopd
vetz wrote:
I just installed and tested the NV1 (3240) on a P120 with 32MB of RAM. I was shocked to see NASCAR Racing running alot better, it's is comparable with the Matrox version and certainly better than software mode!
Can anyone theorize what the hell is going on? On our Pentium III systems we have significant worse performance than on a P120..
It has been quite a while, but I only thought of this now: Could this have something to do with missing write combining (MTRR setup)? Pentium I usually have better video write speed than PII/III without write combining, I don't know if this is compensated by the higher clock rate of your PIII.
Usually in Windows the video drivers set up the registers, but the NV1 was introduced before Pentium II (PPro was released at about the same time but surely wasn't bought a lot by gamers) so it is quite possible that the driver doesn't include this.
Maybe you could try to see which memory ranges are used by the NV1 and enable WC for one or more of those? Unfortunately I couldn't locate a tool to do this in Windows, maybe you are able to find one. Alternatively it might be possible to set up the MTRRs in DOS before starting Windows.
Reply 46 of 46, by Stiletto
Annnnnd it's live.
NVidia NV1 SDK 1.50 has been uploaded:
http://www.vogonsdrivers.com/getfile.php?fileid=706
It includes a demo called 3DSHAPES.
Stiletto
