Building a high end 486 but need advice
Reply 40 of 89, by feipoa
After checking online, it does appear that there were some 120 MHz AMD 486 chips with write-through L1 cache, although from my experience, most 120 MHz AMD 486 chips were of the write-back variety. I do not have any comparative benchmarks for the 120 MHz write-thru chip. I do have benchmarks for the 100 MHz write-thru chip though.
Try setting your L2 cache to write-back. You should use the "engineer mode" to tighten up those cache timings. This will help quite a bit. You also want to tighten up your system memory timings.
If you are looking for a high-end 486, you might want to consider a CPU with 16 KB of write-back cache. Your CPU is 8 KB write-through. The AMD "5x86" 133 chip is 16 KB write-back and the majority of them will run at 160 MHz. If you want a fast 120 MHz system, you can consider one of the WB-enabled Intel DX4-100's or a Cyrix 5x86-100/120. All of the Intel 486 DX4's I've tested work well at 120 MHz. Many users have also had success with a Cyrix 5x86-100 at 120 MHz. For the WB-enabled Intel DX4's, look for an &EW on the face of the chip. If it has &E, those are write-through only.
Reply 41 of 89, by smeezekitty
I tightend everything as low as it would go and set the DRAM speed from "slowest" to "fastest"
Seems to be much better now (amazing how much difference it made). Not sure if it is stable since I cannot boot an advanced OS right now
Norton systeminfo 8 is now 151
I might look for one later
    75.93 KiB
Reply 42 of 89, by feipoa
Your speedsys score has improved some, however I estimate it should be closer to 45. From my benchmark spreadsheet, I do not see any difference in the Speedsys "score" from write-back to write-through on AMD 486 chips. Your L1 speed should be around 80 MB/s, L2 around 56 MB/s, and memory throughput around 44 MB/s. These are results from a UMC 8881/8886 chipset-based motherboard, however I have found them to be fairly consistent among other UMC 8881/8886-based motherboards. I see you are using a SiS 496/497-based motherboard. These motherboards typically perform a little better than the UMC results for memory throughput, however they have about the same L1 and L2 results. I am a little surprised that your memory throughput is 22% slower than the UMC tests. I suspect something is still not quite right.
Which motherboard are you using? Do you have a photo of the board? Did you check the part numbers on the individual memory chips on your memory modules to see if they are EDO or FPM? Does the CMOS have a setting for using EDO memory?
Reply 43 of 89, by smeezekitty
Its an Acer AP43
Here is a crummy picture: http://postimg.org/image/ckugg9ryh/full/
I will try to take better ones later
The RAM chip part number is MT4C4001JDJ
Don't remember a setting for EDO
Reply 44 of 89, by feipoa
That appears to be FPM memory, so I would think it is supported.
The board looks nice, but Acer might be dumbing some of the timings down behind the scenes. You could always try using double-banked 256 KB cache instead of single-banked 256 KB cache. While this shouldn't affect the Speedsys scores, it might affect some OEM-specific dumbing down timings - this is a wild shot though.
I sort of recall seeing this board on eBay sometime within the past 5 months. I think it sold for a reasonable amount. If it didn't have an AMI BIOS, I might have been more interested in it. If it had an AWARD BIOS it would be modifiable to take a PS/2 mouse. Did you check to see if there are AWARD BIOSes for this motherboard, or if Acer has an AMI-updated BIOS?
Reply 45 of 89, by smeezekitty
Why deliberately gimp performance?
If that is as fast as it gets, then oh well. Its still a LOT faster than my DX/33
I plan to try 512KB cache
Here is the listing on ebay: http://www.ebay.com/itm/201053428794?ssPageNa … 984.m1439.l2649
DOn't know anything about the BIOS or how it could be adapter to PS/2
Reply 46 of 89, by feipoa
A February 1996 BIOS - that is pretty new for a board with early 1995 datecode chipsets.
How to mod an AWARD-based 486 board with stand-alone KBC for an aftermarket PS/2 mouse port is discussed here, Native PS/2 mouse implementation for 386/486 boards using the keyboard controller
While there was some effort to get it working with an AMI BIOS, that work has come to an apparent standstill.
Why would an OEM gimp performance? To reduce risk and mitigate potential complications. Here's a excerpt from another post concerning all the complications associated with borderline L2 cache settings on 486s. Zida 4DPS
The majority of motherboards I have come across which have 8 cache DIPs sockets tend to use the double-banked (8 chips) configur […]
The majority of motherboards I have come across which have 8 cache DIPs sockets tend to use the double-banked (8 chips) configuration. I have only taken note that when using more than 256 KB cache, it is sometimes a requirement to reduce the L2 cache timings in CMOS. This is especially true when going from 256 KB, double-banked, to 512 KB, single-banked. 1024 KB, double-banked, also seems to prefer slower L2 cache timings. I have not done a comparison of 256 KB double-banked, vs. that of 256 KB single-banked. It could be that need to reduce L2 cache timings are more dependent on the size of your L2 cache instead of single vs. double banked operation. It could also be that single vs. double-banked operation still plays a role in the need to reduce L2 timings but to a significantly lesser extent.
At one point I was working on all this characterisation on several different motherboards and different 486 chipsets. I had several hundred data points on a spreadsheet, but the issues became further complicated as different CPUs, FSB settings, cache amounts, and even the amount of RAM installed all had different requirements for the maximum usable L2/memory CMOS settings. Then I would need to run Memtest and wait hours for a failure. For any given CPU, it was usually a certain Memtest test # which would fail, but for a different CPU, it would be a different test #. It all began taking way too much time.
The main thing I learned from these experiments were:
  • The more L2 cache (e.g. 1024K vs. 256K), the more system memory (e.g. 128 MB vs. 32 MB), or the faster the FSB (e.g. 40 MHz vs. 33 MHz), the more sensitive the L2 timings will be. The timings in these situations may need to be reduced from the most optimal CMOS settings for a truely stable system.
    The faster or more advanced the CPU is per clock, i.e. a Cyrix 5x86-120 vs. an AMD X5-120 or AMD X5-160, the more sensitive the L2 timings will be. The timings in these situations may need to be reduced from the most optimal CMOS settings for a truely stable system. Some systems, for example, may just barely be stable with an X5-160 at the most optimal CMOS settings given your amount of L2 cache and memory, but not with a Cyrix 5x86-120.
    Having more memory per stick and using less SIMM slots seems to allow for faster L2 timings.
    The most optimal CMOS settings may also be BIOS revision dependent. I have found that using a 4DPS BIOS on a DTK board allowed for using 64 MB SIMMs, while the DTK BIOS did not. Recall from above that using less SIMM slots and denser memory sticks allowed for faster timings.
    Single-banked vs. double-banked cache may have an effect on how tight you can set your L2 timings. It may also be cache size-dependent, however the effects of single- vs. double- banked cache have not been studdied w.r.t. a common overall L2 cache size.
Keep in mind that your requirements for a stable system may be less stringent than mine. If you are OK with Windows 98 crashing during installation, or having failed memory on Memtest, then you might be able to get away with tighter CMOS settings.
Reply 47 of 89, by smeezekitty
I think I will just stick with a serial mouse since it has two serial headers.
BTW Just for fun I plugged my serial mouse into my Vista machine to see what would happen and IT WORKED
When I get a chance, I will post all the BIOS options.
The part about stability kind of gave me a headache with all the combinations.
Even if it isn't the fastest board it will still be the fastest 486 I have ever had.
Thanks again
I will see what I can do. Might have to end up loosening the timing with 64/128 RAM and 512 cache
Reply 48 of 89, by feipoa
I forgot to mention that these cache caveats are mostly an issue when using an FSB at 40 MHz and greater.
Reply 49 of 89, by smeezekitty
Well since it is a 120MHz CPU it needs to run at 40MHz to reach its rated speed.
In any case, I found a case (pun intended)
Story here:http://www.vintage-computer.com/vcforum/showt … nteresting-find
Basically I found an old 386 AT case with a dead socket 7 board in it at the recyclers. Not much point keeping that in there.
--edit---
🤣! I just open the USB card I received from ebay and there was two in the package with two different chipsets.
Maybe that will help the chances of one working
Reply 50 of 89, by sliderider
Not necessarily. My Cyrix 5x86 120 supports a 4x multiplier which suggests that there was at one time a motherboard out there somewhere with a 30mhz bus speed setting, most likely a proprietary design in an OEM system rather than a retail board.
Reply 51 of 89, by smeezekitty
NSSI report:
		     Navr til Software System Information
Version 0.60.45
Report File
Tuesday, 2014-04-22 19:46
Switches: /AR
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛGeneral InformationÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Computer PC-AT or compatible, ISA + PCI º
º Processor Intel i486DX or i487SX, 120 MHz, V86 mode, 2/4/19/15 º
º Co-Processor Internal, 120 MHz, 3/3/100/22 º
º BIOS AMI WinBIOS, American Megatrends, Inc., PnP, 10/10/94 º
º Video Diamond SVGA 4 MB, VESA VBE 1.2, Secondary: None º
º Memory 16 MB, 640 KB, 15360 KB, XMS(3.0,15296 KB), EMS(4.0,15 º
º Drives HDD1: 488 MB º
º Oper. System MS-DOS version 6.0 º
º Mouse Not Detected º
º Input Devices AT Enhanced Keyboard (101 key), Ncsi, No Joystick(s) º
º Ports 2 Serial, 1 Parallel, 0 Game º
º CMOS FDD1: 1.44 MB 3«", FDD2: None º
º Network Not Detected º
º Multimedia Not Detected º
º Software Not Detected º
º Other Not Detected º
ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛComputer DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ General ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Computer Type PC-AT or compatible º
º Computer Name Unknown or Noname º
º Model FCh º
º Submodel 01h º
º Revision 00h º
ºÄ Mainboard ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Bus(es) ISA + PCI (2 devices) º
º Chipset SiS 496/497 (Method 1) º
º Manufacturer AOpen (Acer Inc.) (Method 2) º
º Type AOpen AP41/AP43 º
º System Bus Speed 120 MHz (multiplier 1.0x) (Method 1) º
ºÄ ISA Devices ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º No Devices/Cards Found º
ºÄ EISA Devices ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º EISA Bus Not Present º
ºÄ PCI Bus Features ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º PCI/AGP Bus Version 2.10/n/a º
º Number of Last PCI Bus in System 0 º
º Configuration Space Access Mechanism 1 Supported º
º Configuration Space Access Mechanism 2 Not Supported º
º Special Cycle Generation Mechanism 1 Not Supported º
º Special Cycle Generation Mechanism 2 Not Supported º
ºÄ PCI Bus Devices ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Vendor ID 1039h, Device ID 0496h, Bus 0 - PCI, Device 5, Function 0 º
º Vendor Silicon Integrated Systems º
º Device SiS 85C496/497 486 Chipset (CPU/PCI & PCI/ISA Bridge) º
ºÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
Show last 298 lines
  º Vendor ID 5333h, Device ID 5631h, Bus 0 - PCI, Device 11, Function 0   º
º Vendor S3 Incorporated º
º Device S3 ViRGE (86C325) Video Adapter º
ºÄ PCI Bus Device Characteristics ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Device Class PCI/Host Bridge º
º Device Revision 31h º
º Interrupt Line None º
º Interrupt Pin None º
º ROM Base Address n/a º
ºÄ PCI Bus Device Features ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º I/O Space Access Enabled º
º Memory Space Access Enabled º
º Bus-Mastering Enabled º
º Wait Cycles Disabled º
º Fast Back-to-Back Disabled º
ºÄ PCI Bus Device Capabilities ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Running at 66 MHz Not Capable º
º Fast Back-to-Back Capable º
º Device Timing Medium º
º Device Class VGA Compatible Adapter º
º Device Revision 06h º
º Interrupt Line IRQ9 º
º Interrupt Pin INTA# º
º ROM Base Address 80000000h º
º Fast Back-to-Back Not Capable º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛProcessor DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Main Processor Intel i486DX or i487SX, 120 MHz º
º CPU ID n/a º
º Stepping n/a º
º CPU Vendor n/a º
º CPU Name n/a º
º CPU Serial Number n/a º
º Run Mode Virtual 8086 º
º CPU Type Original OEM Processor º
º 1st Level Cache 8 KB (Method 1) º
º 2nd Level Cache n/a º
º 3rd Level Cache n/a º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛCo-Processor DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Co-Processor Type Internal, 120 MHz º
º Communication Protocol 32-bit º
º Co-Processor Emulated No º
º Emulation Software n/a º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛBIOS DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º BIOS Type AMI WinBIOS º
º BIOS Manufacturer American Megatrends, Inc. º
º BIOS Date 10/10/94 º
º BIOS Version n/a º
ºÄ BIOS Features ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Flash BIOS Present (AMI, version 2.00) º
º Green PC/Energy Star Present º
º BIOS32 Services Present º
º Plug and Play Support Present (version 1.0, 0 devices) º
º DMI Support Not Present º
º SMBIOS Support Not Present º
º APM Support Not Present º
º ACPI Support Not Present º
º ACFG Support Not Present º
º PCI IRQ Routing Table Not Present º
ºÄ ROM Modules ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Address Range Size Type PnP º
º C000h - C7FFh 32 KB SVGA BIOS º
º E000h - E0FFh 4 KB System ROM º
ºÄ Plug and Play Devices ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º No Plug and Play Devices Present º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛVideo DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Video Adapter SVGA º
º Monitor Type SVGA Digital Color º
º Secondary Video Adapter None º
º Secondary Monitor Type None º
º Video Chipset S3 ViRGE (86C325) (Method 4) º
º Video Card Diamond Stealth 3D 2000 º
º Video Memory Size 4 MB º
º Video Card Bus PCI º
º Video RAMDAC Type S3 ViRGE Internal SDAC TrueColor, 135 MHz º
º Video BIOS Manufacturer S3 Inc., Diamond º
º Video BIOS Model Stealth º
º Video BIOS Version 1.04 º
º Video BIOS Date 01/23/97 º
ºÄ VESA Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º VESA Support Present (VESA Memory Size 4 MB) º
º VESA VBE Version 1.2 º
º VESA Manufacturer S3 Incorporated. 86C325 º
º VESA Power Management Present, VBE/PM version 1.0 º
º Display Data Channel Present º
º Accelerator Functions Not Present º
º Audio Interface Not Present º
º Flat Panel Interface Not Present º
º Cursor Interface Not Present º
º Graphics System Conf. Not Present º
ºÄ VESA VBE 2.0 Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º OEM Software Version n/a º
º Vendor Name n/a º
º Product Name n/a º
º Product Revision n/a º
ºÄ 3D Graphics Acceleration ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Internal 3D Accelerator S3 ViRGE º
º External 3D Accelerator No Known Found º
ºÄ Monitor Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Monitor Name DELL 1901FP º
º Monitor Type 21" º
º Viewable Image 19.3"/49 cm º
º Serial Number 1094988621 º
º Date of Manufacture 29. week of year 2004 º
º Max. Horizontal Size 38 cm º
º Max. Vertical Size 31 cm º
º Display Type RGB Color º
º Voltage Level 0.700V/0.300V (1.000V p-p) º
º Input Signal Type Analog, Composite Sync, Sync on Green º
º Gamma Factor 2.20 º
º DPMS Support Standby, Suspend, Active OFF º
ºÄ Additional Video Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Video BIOS Segment C000h º
º Video BIOS Size 32 KB º
º Scan Lines 400 º
º Character Size 9 x 16 º
º EGA Switches 0110 º
º CGA Cursor Emulation Disabled º
º Current Video Mode 3 º
º Video Segment Address B800h º
º Video Page Size 4 KB º
º CRTC Port 3D4h º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛMemory DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Total Memory 16 MB, Memory over 1 MB 15360 KB º
º HMA Exists Yes º
ºÄ Conventional ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Total 640 KB, Used 249 KB (39%), Free 391 KB (61%) º
º Used by DOS 22 KB (3%) º
ºÄ XMS ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Present Yes, Version 3.0 º
º Manager HIMEM, Revision 3.09 º
º Total 15296 KB, Used 1273 KB (8%), Free 14023 KB (92%) º
ºÄ EMS ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Present Yes, Version 4.0 º
º Manager EMM386, Revision 3.09 º
º Total 15680 KB, Used 1424 KB (9%), Free 14256 KB (91%) º
º Page Frame D000h º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛDrives DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ IDE Drives ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Primary Master IDE Drive º
º Primary Slave None º
º Secondary Master ATAPI Drive º
º Secondary Slave ATAPI Drive º
º Tertiary Master None º
º Tertiary Slave None º
º Quaternary Master None º
º Quaternary Slave None º
ºÄ Non-IDE Drives ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º None Found º
ºÄ ATAPI Drive Physical Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Drive Model pppppppppppppppppppp º
º Firmware Revision pppp º
º Serial Number pppppppppp º
º Device Type Unknown º
º Drive Features DMA º
º Drive Manufacturer Unknown º
º Estim. Drive Speed n/a º
º Removable Device Yes º
º Transfer Modes PIO 8, SW DMA 3/6, MW DMA 0/6, Ultra DMA 0/6 º
º Drive Features DMA, IORDY º
º Transfer Modes PIO 8, SW DMA 3/6, MW DMA 3/6, Ultra DMA 3/6 º
º L Drive Type Label Total Free Used º
º A: Floppy Drive 1.44 MB 3«" n/a n/a n/a n/a º
º C: Local Hard Disk n/a 486 MB 480 MB 6 MB º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛOperating System DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Operating System MS-DOS º
º DOS Version 6.0 º
º True DOS Version 6.0 º
º DOS Revision 0 º
º User Serial Number 000000h º
º DOS OEM Microsoft or Phoenix º
º DOS is in HMA º
º Boot Drive A: º
º Last Drive Z: º
º BREAK Off º
º VERIFY Off º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛPorts DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Serial ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º COM Port UART TimeOut Rate Data Stop Parity CD RI DSR CTS º
º 1 03F8h 16550A 1 s 1200 bps 8 b 1 b None No No No No º
º 2 02F8h 16550A 1 s 1200 bps 8 b 1 b None No No No No º
ºÄ Parallel ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º LPT Port EPP TimeOut TIM IOE SEL OOP ACK NBZ º
º 1 0378h n/a 20 s No No Yes Yes No No º
ºÄ Game ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º JOY Position X Position Y Button 1 Button 2 º
º 1 0 0 Released Released º
º 2 0 0 Released Released º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛNetwork DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Detected Network(s) ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º No Networks Detected º
ºÄ Network Services/Protocols ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Not Detected º
ºÄ Network Card(s) ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º No Network Cards Detected º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛMultimedia DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Sound Card ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º BLASTER Type Non-Creative Labs card compatible with SB 2.0 Bits n/a º
º Specific Type same as above Bits n/a º
º Settings Port n/a, IRQ n/a, DMA n/a, High DMA n/a, MIDI Port n/a º
º DSP Version n/a T 1 º
º AWE Features n/a º
º Compatibility n/a º
º Features n/a º
º Manufacturer n/a º
º DSP Copyright n/a º
º Accelerator No Known Found º
ºÄ CD-ROM ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º MSCDEX Status Not Installed, Version n/a º
º CD-ROMs 0, Letter(s) n/a º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛSoftware DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Detected Software ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Microsoft EMM386 or compatible, Mode ON º
º Virtual Control Program Interface version 1.00 º
º XMS Memory Manager º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛOther DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Miscellaneous ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Modem Status Not Found º
º Modem Type n/a º
º Scanner Not Found º
ºÄ PCMCIA Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º PCMCIA Not Present º
Reply 53 of 89, by Anonymous Coward
30MHz motherboards definitely exist. That's why there's such a thing as an AMD DX4-90
Reply 54 of 89, by smeezekitty
486 machine is coming together
Wish I had shorter IDE/floppy cables.
Major spaghetti. I don't have a proper form factor PSU so i am using a tower style AT supply for now.
Installing DOS right now
Reply 55 of 89, by smeezekitty
Woohoo!!!
Installed Windows 95 and Opera 8.50 and posting from it right now.
Kind of slow but it works!
Now I still need to get a proper CPU cooler and powersupply but still it is running well
Win 95 was a pain to install. That is for sure
Reply 56 of 89, by feipoa
I found IE6 to be faster than Opera 8.5x on a 486. I'm not sure why you would have trouble installing Win95. That has always been a breeze for me on a 486. If you thought Win95 was a pain, stay away from Windows NT.
Reply 57 of 89, by smeezekitty
Right now the biggest reason it is so slow is the 16 MB of RAM. I have 64 MB on the way.
First I tried to install 95 from floppy. After several tries it would always complain about not being able to read the setup disk.
I gave up and installed a CDROM drive (I was going to anyway). Dug out a win 95 disk and it went through the whole install process
just to hang on startup on the next reboot. Trying to start it from a floppy caused a blue screen.
I ended up formatting the CF card and starting over. This time it installed and loaded windows on the next reboot
but then when it was loading drivers on the first run, the cdrom could no longer be found so I ended up copying the files one by one as it asked for them with a floppy.
Once it was done the CDROM worked again but then I had trouble with the network driver installation.
Reply 58 of 89, by RacoonRider
I've got the same motherboard and I'm building a system of it as well. Here comes a warning: do not buy Tseng Labs ET6000. In my case, the card works well in P233MMX, PII-333, PII-450 and shows nothing but garbage when installed into AP43.
There's also an interesting fact: the board bears Acer serial numbers and stuff and bears AOpen logo, yet the AOpen company itself was incorporated only in December 1996, almost two years after the board's release. That's kind of a mystery.
Reply 59 of 89, by smeezekitty
I am using an S3 Virge and it is working well. thanks for the info though
Aopen is (or was) part of Acer
One annoyance if you haven't found it already is there is no output for an HDD light. I am thinking of soldering the HDD light to my CF card adapter to make it work
