Scali wrote:I don't see an ISA ET4000 though, so this proves nothing.
Besides, this is a DX4 and you get those framerates? Makes me wonder w […]
sunaiac wrote:One of the ISA line is a bad copy/paste, but should give the general idea.
However good is a chip, ISA will be to slow for it to be "about as good" as mid range VLB in doom.
Besides, this is a DX4 and you get those framerates? Makes me wonder what you tested and how.
If I recall, my 486DX2-66 rarely dipped below 35 fps.
And if you do the math, it certainly is possible to reach 35+ fps over an ISA bus in 320x240 in 256 colours.
Edit: here are some results including ET4000 ISA cards on a Pentium 100:
http://thandor.net/benchmark/32
The fastest ISA card is an ET4000AX 1MB ISA(P100), getting 32 fps average. Which is certainly in the ballpark of VLB cards. And 32 fps is also in the reach of a 486.
I'm a strange guy, I don't compare numbers from tests that are not using the same protocol. Double standard thing, remember ?
And I'm also not interested in theories. I give hard numbers I obtained myself.
How I tested is not a secret. I used phil's benchmark suite.
Main difference between phil's configuration and that P100 guy is that doom is fullscreen in the first case, fullscreen -2 in the second.
Hardware is a HOT419/256kb + 64MB FPM + Tekram DC680-T/4mb + intel DX4-100, dos started with "F5".
The 5434 is in the top list of ISA cards, as proved by another thread here on VOGONS.
I'll put in that Western Digital that came first in aformentionned thread, since I don't own a ET4000 on ISA bus, only VLB and PCI.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
