Reply 40 of 162, by ramiro77
Allright! I'll try that!
Meanwhile I have some news. I installed w98se again. This time no serial/parallel ports enabled and no sound card. I'm using nVidia's riva 128zx pci driver 3.37. Windows GUI behaves correctly as I said. Windows screensavers behaves correctly as well.
Direct3D tests: when it runs in software mode I see two times the moving screen issue. In hardware mode it runs perfectly. Directdraw works flawlessly.
3Dmark99: I have less "moving screen" episodes, but they are still there. Demo mode works really better. In benchmark mode I was not able to run it complete because the card freezed in the ten first seconds:
This is the same behavior as I get with one particular driver (I can't remember which one). I tried running the test another time but at 640x480 and I didn't get that crap. But still some little amount of "moving screen" issue. At number 14 test the system hanged showing a VxD error again. I had to manually reboot.
I checked the card and it seems to be running ridiculously hot. The tiny heatsink burned my finger. Is this ok? I don't think so. I have my case opened right now and the ambient temperature is around 70ºF.
Also I checked every bios setting. I disabled everything related to video card. I don't know what else to try before asking for refund...
