Quake without FPU
Reply 40 of 118, by kixs
RapidCAD@40MHz:
Shareware v1.06 : 2.8 FPS
Tronix no FPU v1.09 version: 2.1 FPS
All run from Quake shareware directory.
Reply 41 of 118, by kixs
Changed the cpu for Ti486DLC.40 and Quake v1.09 DJGPP ... [NO FPU] upon start gives an error:
Quake requires a floating-point processor.
Reply 42 of 118, by Tronix
kixs, not bad. You can compare this result with attachment EXE file - its compiled with FPU-optimized asssembler functions with DJGPP 2.05, GCC 9.2.0, with CFLAGS=-O9 -march=i586 -Wall -fomit-frame-pointer -ffast-math
    quake_i586.zip
    374.93 KiB
    46 downloads
https://github.com/Tronix286/
Reply 43 of 118, by Tronix
Hm, okay, i commented signal(SIGNOFP, Sys_NoFPUExceptionHandler); string in sys_dos.c file. Recompile. Try this version plz.
    quake.zip
    359.75 KiB
    44 downloads
Reply 46 of 118, by Tronix
kixs wrote:
But still won't run...
Hmmm... Last try - compiled with -wmemu (libwmemu.a)
    quake.zip
    362.58 KiB
    63 downloads
Reply 47 of 118, by kixs
Great success 😁
This is with Ti486DLC-40, 256kb cache, 32MB RAM, VLB S3 864 2MB and VLB I/O.
Don't ask be about FPS as this is slooooooooooooooooow. It took a minute or even more to draw what I photoed 🤣 I even thought it froze at one point before loading the demo. If I had to guess it takes around 13-15 second to do one frame. Will decrease the size of screen to a minimum 🤣
Reply 48 of 118, by kixs
With minimum screen size it still takes around 5-10 seconds per frame - I guess more complex scene as there are the first enemies in a DEMO1.
It threw the grenade and it took 18 seconds. For explosion it took 25 seconds per frame.
Reply 49 of 118, by BinaryDemon
Awesome work Tronix and kixs! kixs can you test vs Shareware Quake w/Q87? I’m curious if there’s any benefit other than not requiring Q87. What a fascinating thread!
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 51 of 118, by BinaryDemon
Ok that’s basically what OP experienced although georgel insists it does/will.
Reply 52 of 118, by kixs
In the Q87 readme it mentions only 486SX to run Quake. So I've gone to find the 486SX2/66... I've put it on the 40MHz clock and it runs now at 80MHz. It does run Quake with Q87X 😁
I'll test the Quake with Q87X and Non-FPU version. My guess is that Q87X will be quicker.
Will do some benchmarks...
Reply 53 of 118, by kixs
Benchmarks:
Amd486SX2@80Mhz
Quake v1.06 with Q87X - max screen size ... 1.1 FPS
Quake v1.06 with Q87X - min screen size ... 1.7 FPS
Quake v1.09 NO-FPU - min screen size ... 0.2 FPS 🤣
Reply 54 of 118, by georgel
Good. Q87/Q387 is the fastest of all other FPU software emulation routines that you may come across. Quake may be picky about the expanded memory manager as I mentioned before, so I strongly advise you to try instead of EMM386 QEMM or 386MAX and not to blame Q87 alone for your failures to run Quake. Quake will of course run much better on NexGen than on 486. If someone needs run codes for Q87/Q387 for your machines, let me know.
Reply 55 of 118, by kixs
The same system configuration and Quake runs with Q87X on 486SX2/66 but it won't on a Ti486DLC. Of course the motherboard is also different.
NexGen... I'd like that system... but locally someone is selling it as-is for quite a bit of money and I just can't justify throwing money to the BIN if it doesn't work 🙁
Reply 56 of 118, by georgel
This does not mean that the EMM is not problematic on the DLC. How much RAM do you have on both platforms? Is the RAM on the DLC thoroughly tested for failures? QEMM is not only much superior compared to the EMM386 but is outputing more informative error messages...When you run Q87 on the DLC is it recognized as a coprocessor by detection utilities like checkit?
OFFTOPIC: is the RapidCAD's coprocessor working with the Ti486DLC?
Reply 57 of 118, by kixs
Quake crashes. Not EMM.
486SX2 has 16MB
486DLC has 32MB
All tested and run without errors otherwise.
But this isn't an issue for me as it would run way too slow.
Updating the above benchmarking thread as NO-FPU Quake just finished in almost two hours 🤣
Reply 58 of 118, by georgel
This is what you see and your conclusion is quite simplistic since you don't know what causes the crash! When quake runs there is a lot of underlying software that runs too: the BIOS and BIOS extensions, the DOS and its TSRs, the EMM (the PM hypervisor), Q87 (the hypervisor's extension), DOS4GW (The PM DOS extender that gets its memory from the EMM's pool and switches constantly between PM and RM via EMM's VCPI and provides flat memory PM context to quake while serving all quake's OS requests passing them to DOS/BIOS and other RM handlers that may be present in the system), and on top of these runs Quake. It's like a concert.
Reply 59 of 118, by BinaryDemon
Kixs going the distance with the testing! I don’t think OP is going to get playable FPS on his Nexgen CPU, looks like he should invest in a 3D card.
