Tell me I don't need a LGA1366 platform PC
Reply 40 of 81, by Brawndo
Ok well I couldn't stop thinking about it and I caved, just bought this bundle for $120 USD, which to me is a fair price. Yeah it's cringe worthy that it was placed bare on a rug to take the pictures, but I'll just have to test thoroughly and make sure it all still works.
ASUS Rampage II Extreme
i7 980X
12 GB (6x2GB) Corsair Dominator CL8 RAM
I likely will put a full Creative card in it and not use the half length PCI-E card.
Reply 42 of 81, by cyclone3d
Brawndo wrote on 2023-05-02, 00:21:
Ok well I couldn't stop thinking about it and I caved, just bought this bundle for $120 USD, which to me is a fair price. Yeah i […]
i7 980X
What speed is that RAM?
On a side note, it is generally easier to overclock this platform as far as the IMC goes when only using 3 RAM slots.
Pair that setup with a Noctua NH-D14 or D15 and some higher airflow fans and you will have a very nice 1366 setup.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 43 of 81, by TrashPanda
cyclone3d wrote on 2023-05-02, 00:23:
What speed is that RAM? […]
i7 980X
I kinda caved and grabbed a EVGA 280 CLC for my build, it was on clearance for 50% off NIB so worth grabbing.
Should be able to really push the OC with that cooler.
Reply 44 of 81, by cyclone3d
TrashPanda wrote on 2023-05-02, 00:32:
i7 980X
Nice!
Heh, my current system - AMD Ryzen 5950X has a 420 setup with 6x 300cfm fans... Bwahahahaha!
YMF7x4 Guide
Reply 45 of 81, by Brawndo
RAM is 1600 MHz 8-8-8-24, and being Corsair Dominator should be able to overclock well beyond that, maybe even bump the timing up to 9. Regardless I'll push it as far as it can go reliably while keeping the voltage close to stock to keep the hardware alive long term, no need to go extreme with overclock considering I also have a Sandy Bridge system 2 years newer and a Core i7 4790K system, not to mention my current Ryzen desktop, all of which can easily handle anything the 1366 can't.
Reply 46 of 81, by Brawndo
cyclone3d wrote on 2023-05-02, 00:48:
My current desktop is a Ryzen 5950X with an Optimus water block, and a Gigabyte RTX 3080 Waterforce, all cooled by two 360mm radiators and a Swiftech MCP655 pump. The case is massive and has 8 120mm fans and 2 140mm fans. Stays cool as a cucumber no matter what I throw at it.
Reply 47 of 81, by TrashPanda
Brawndo wrote on 2023-05-02, 00:58:
I bought a Fractal Define 7XL .. huge case is an understatement, can fit a 420 with room to spare, needed it to fit the Liquid Freezer II 420 as its a chonky boi with the rad being extra thicc.
Reply 48 of 81, by Grem Five
Well let me reiterate the title of the thread:
OK... you dont need a LGA1366 platorm.... there told you again.
Reply 49 of 81, by cyclone3d
TrashPanda wrote on 2023-05-02, 01:50:
My radiator is super thicc as well. The radiator is actually mounted on the outside of the case.
It is an all copper and brass Thermaltake radiator. The case is a full tower Lian-Li PC-V2120B. Stock it was only meant to house a 360mm. I made a template for the 420 Thermaltake and spent quite a bit of time getting everything just right before modding the case.
YMF7x4 Guide
Reply 50 of 81, by TrashPanda
Wooo Copper and Brass would make a sexy looking Rad.
Reply 51 of 81, by cyclone3d
TrashPanda wrote on 2023-05-02, 02:29:
It is painted black from the factory..
Here is Thermaltake's product page for it:
https://www.thermaltake.com/pacific-cl420-radiator.html
YMF7x4 Guide
Reply 52 of 81, by Brawndo
Grem Five wrote on 2023-05-02, 02:25:
Too late! 😁
Reply 53 of 81, by Brawndo
I have the Corsair 5000D. It's a really well thought out design, room inside the case for two 360mm rads plus fans and an additional 120mm in back if you wanted. Tons of room inside, and mounting slots on the panel behind the motherboard tray for four 2.5" SSDs, plus two 3.5" HDD slots on the bottom next to the PSU.
Reply 54 of 81, by Grem Five
I'm knida confused why I keep hearing the X5675 has a locked multiplier.
I'm running it at x25 when its suppose to be x23, and only cooling it with a Cooler master hyper 212... the original one I bought back in 2010 or 2011.
Reply 55 of 81, by TrashPanda
Grem Five wrote on 2023-05-02, 03:02:
I'm knida confused why I keep hearing the X5675 has a locked multiplier. […]
It doesnt, no idea why people think it does.
Reply 56 of 81, by Grem Five
According to https://www.cpu-world.com/Compare/703/Intel_C … Xeon_X5675.html
It lists it doesnt have an unlocked multiplier but my system seems to show me different.
I should get it better cooling and try to drop the core voltage to use the least voltage possible for a stable setting but the system is rarely run, maybe some day.
Reply 57 of 81, by The Serpent Rider
Multiplier is locked, but many boards provide additional manual control over TurboBoost multipliers on Nehalem family of CPUs, which is +2x to stock speed. By Intel spec, +1 is applied if CPU does not exceed TDP limit and +2 is applied when only one core is active (HT thread is included).
Reply 58 of 81, by agent_x007
^That + you overclock LGA 1366 through BCLK (and adjusting QPI/UnCore multipliers down when necessary), and not with Core multiplier.
Reply 59 of 81, by TrashPanda
The Serpent Rider wrote on 2023-05-02, 04:14:
Multiplier is locked, but many boards provide additional manual control over TurboBoost multipliers on Nehalem family of CPUs, which is +2x to stock speed. By Intel spec, +1 is applied if CPU does not exceed TDP limit and +2 is applied only when one core is active (HT thread is included).
X5675 doesnt have a locked core Multi according to the few sites ive checked, it does have a locked memory multi of 10x but its also got the best IMC of the series so it should be able to push memory better than other models.
