swaaye wrote:I think the problem with ME was that enthusiasts wanted what became XP. There was another NT OS codenamed Neptune that was a precursor to XP but it was canceled.
I actually tried Neptune shortly before I moved but never got further then basically browsing around, looking how it worked, before I moved and eh..kinda misplaced the parts of the original configuration.
Of course it was a beta and not many drivers were available for it.
It's an interesting OS, from a vintage point of view at least. Perhaps later I'll build a rig around it again.
And about 2k, I tend to agree. I don't see any real reason to use 2k over XP on newer systems and ME on slower ones. On slower systems ME is much faster then 2k and XP wouldn't be any slower..so why use 2k?
Perhaps a reason would be because someone prefers to use 2k in particular and knows his/her way around that OS, much like I prefer ME over 98SE or 2k.
I only came in touch with 2k and with 98SE a couple years after I had started using ME and have always preferred XP over 2k on newer rigs (especially since it works with more modern stuff and I know my way around it better).
That still never stopped me from actually giving both 98SE and 2k a try though 😉
2k does have one advantage it shares with XP, it will work with nlite 😉
Though otoh, ME should work with msbatch just like 98SE and before.
I agree about memory being of more importance then CPU when it comes to minimum requirements and memory certainly is much more affordable then it used to be. But still, I'd rather not buy 4x128MB EDO simms for €€€++ only because I want to use XP on a Pentium 1. If I can get 512MB SDRAM for dirt cheap, I'd prefer to spend the cash I save that way cash on something else and will settle for another OS and less ram for the older rig.
Also for instance if building a Super 7 rig with a K6-2, putting more ram in a rig then what it can cache, I prefer to add the max memory the system can cache and select what OS to run on that ram later.
I can understand someone without any prior experience with ME to prefer not to use it (kinda like I prefer not to use 2k or 98SE), partially because of all the bad press it's been getting, but I'd say:"Do a bit of reading and try for yourself!" 😉
