Reply 60 of 124, by dionb
imi wrote:
thank you ^^ and done.
will be really helpful testing unknown condition boards... or uh, boards that have the cache sockets mounted the wrong way *cough*
Yep. These are too expensive to use as generic converters in all systems, but on the test bench for that all-important first boot they should be a lifesaver.
I backed too of course 😀
Reply 61 of 124, by imi
Doornkaat wrote:
I think they're regular Molex products. Correct me if I found the wrong product here.
I know they do exist, they're just hard to come by and pretty expensive in low quantities, so I understand not going that route.
a good DC/DC converter with 20A+ costs about the same as a good ATX PSU 😉
and if you add up the ATX PSU you need to power the adapter itself and an extra DC/DC board I think it makes more sense to just get an ATX PSU in the first place.
also I think the main purpose behind the board is protecting low-power stuff from too much current from a modern PSU in case of a failure.
Reply 62 of 124, by xsecret
Some answers :
1. 20/24 pins Mini-Fit JR (Molex) Male connectors for PCB mount are rare and expensive. It will also be bulky because there is no angled male connectors. And more important, the whole converter will be limited to PC only because it must follow the standard ATX pinout at output. I really want to keep the optional GPIO that can be useful on some Atari/Amiga (ie: to generate a sync signal)
2. The ATX2AT Smart Converter is rated to 10A @ 5V, 5A @ 12V, 0.4A @ -12V and 0.4A @ -5V (for a total of ~120W max excluding peripherals/HDD/ODD). That covers all PC motherboards with AT P8/P9 connectors, from 8088 to Pentium/K6, and almost all vintage "family" computers up to ~1995. Basically, everything that don't require +3.3V from the ATX era.
ATX2AT Smart Converter - Universal Chip Analyzer - CPU-Z Validator - Engineering Sample Zone
Reply 64 of 124, by root42
Extremely cool! Looking forward to getting this nice piece of equipment!
YouTube and Bonus
Reply 66 of 124, by xsecret
I ordered a bit more quantities.
Just drop me an email at dev // x86 - fr and I'll send you a message when they're ready 😀
Reply 67 of 124, by root42
xsecret wrote on 2020-02-26, 09:33:
Cool! Looking forward to the finished product! I hope you are recovering well!
YouTube and Bonus
Reply 68 of 124, by justajeffy
Will do!
Reply 71 of 124, by root42
Got mine as well. Am impressed! Although one thing: I had to set the +12V to 3.0A or else with a couple of cards and two floppy drives it would trigger on power on. After everything has settled it uses 0.2A on +12V. 2.2-2.5A on +5V.
I have a 286@12MHz, two floppies, Compact Flash, Multi I/O, TNDY, SnarkBarker, PC MIDI, ET4000.
YouTube and Bonus
Reply 72 of 124, by cyclone3d
Ohhhh.. yay! Can't wait to get the couple I ordered.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 74 of 124, by root42
Sneak peek at what you will receive:
847.77 KiB
YouTube and Bonus
Reply 78 of 124, by root42
Killian wrote on 2020-07-25, 07:05:
Can I still use the regular AT power on switch with this? Do I just connect the corresponding 2 pins on the board with the existing switch?
It has a regular two pin connector for ATX power switches. Since ATX switches are momentary, your AT power switch might not work as expected. AT power switches actually switch the mains voltage, as far as I understood. I guess you can technically still use it for switchting, but I guess it's more like click on/click off for turning on, and same again for switching off. Replacing it with a momentary switch would be better, I guess.
YouTube and Bonus
