OS = W95. I installed the SB16 driver kit [1994 Win3.1 full install] via an MS Dos Prompt, and it seemed to go in fine - edits boot config files, sets up program group, etc. No other audio devices on the PC. I feel like I'm missing an elementary step here. Or it's a hardware problem..
I'll also try running diagnose in a restart to dos just to see what happens. The only drivers I have right now are dos/win31 which I thought worked in w95. But getting late here so project for tomorrow - thanks for you help!
yup... no point using those ancient Win3.1 drivers and utils with win95... not that it doesn't work, it's inefficient and doesn't behave properly
you should download the newest win98 compatible drivers... it's on vogons drivers.... my "super" ISO will have everything you need 😀
The SB16AWE Compilation v4.1? Got it. Will try the setups in the WIN95 & WIN9XDRV subfolders. So the Vibra16 is sort of AWE card then? I noticed it appeared in Device Manager as a "SB 16 or AWE 32" card..
EDIT: btw I tried a restart to DOS and ran Diagnose [on the old dos/W31 drivers] and had same red error screen attempting to set the Midi address. Now I'll give the W95-98 drivers a shot.
My XR385 died on me, no idea how that happened, anyways I ordered some new ones.
Wow that's a fancy applet! Very cool, though I have no idea what it is you are trying to say 😀
The NEC 385 IS indeed very loud. Most games clip if used on a Roland MPU401AT and that unit doesn't have a mixer at all. So if your gamed doesn't have a volume slider you are out of luck...
Look at the waveforms, the upper wave is the input signal and the lower one is output. Lower frequencies are amplified too much, resulting in clipping, and higher frequencies are filtered out almost completely (-30dB at 20KHz)
If the purpose of this circuit would be to amplify the DAC output to 2Vrms, which would make sense as that is standard line-level signal, something like this would be much better:
I added a separate 2V line-out to bypass the sound card's mixer, and divider for the wave blaster connector to 1Vrms, that might be necessary for some sound cards. The YMF71x for example takes 1V input.
the Vibra16 is a variant of the SB16.... it was meant to be a lower cost chip as it is more integrated... earlier SB16 drivers do not work with it as it is a completely different chip as said
my ISO will have all of those 16-bit sound blaster drivers
you will need to install the updates after installing the main apps and drivers... read the readme and index files to find out everything on that CD
Well, making some progress - like I said I'm a rookie with Midi and mult-audio card setups so "million monkeys/million years" applies. First off I realized I needed to hand set Dev Mgr from default configuration 220/5/1/1 to an alternate preset 220/330/5/1/5 to enable the 330 port at all. That done I completed the midi section of Diagnose.exe., ran the sound tests, updated the config, etc.
Quickly tested a few dos games and discovered that 'Roland' is checked as a supported option in some, meaning I suspect that the midi port is functioning even if the XR385 is not the appropriate DB for Roland. I've tried General Midi, but haven't gotten far with actually comparing sounds. Doom Ultimate seems more full-bodied, but I'm not sure yet if thats the XR385 or simply that I've finally activated features [OPL?] on the Vibra16-S that I hadn't previously been aware of. It's DSP 4.13 and I have had notes hang/lockup so far, though if this is the infamous 'hanging note bug' or just improper game audio setup I don't know yet.
EDIT: everything up and running properly with the XR lashed to a CT1750 [DSP 4.05] I had in the parts bin. After the drivers were installed and the card configured with DIAGNOSE/SETMIXER everything was fine. The midi effects are quite impressive in games that can enable itand I've become quite attached to XR so far and I may pick up another for the W98/MX300 box...
Nice thing is driver lines can be deleted from boot config files freeing up a lot of conventional memory as only the SET variables are actually needed. I get 608kb in a W95 dos box and 611 in a pure dos setting..
Sorry to bump this, but I'm having a big problem with my XR385 which finally arrived this morning. I hook it up to the connector on my CT2940 Vibra 16, and turn on my 486. While posting, and randomly during boot, I hear loud static through the speakers, which increases in volume upon loading Mixerset (makes sense since that's setting the MIDI volume higher). Then, it goes quiet, but whenever I try to use General Midi in a game (I've been using Doom to test) I either get static whenever it should be playing music, or silence. Digital effects through the Sound Blaster are still working fine. Oddly enough though, I changed Doom to use the Sound Blaster for music and after a short period, the static came back on top of the FM music.
Anybody have any suggestions or things I could try, or is it probably dead? The midi port is set to 330H, and the board looks fine (I don't see any scratches or missing capacitors). Should I try cleaning it with some water or alcohol or something? Because the packaging it came in was a bit dusty. I just thought of another idea, I'll blow out the connector with compressed air to make sure theres not dust in it preventing contact. That actually was a problem for me once with a Sound Blaster Live, where dust in a PCI slot kept it from working.
I dont know the amount of gear you have but basically id try changing every variable. ( computer, host card, testing mpu-401 with external module, clean connectors ... ) And see if problem persists.
Well I think I found the problem. Upon closer inspection (apparently I was blind the first time), the capacitor C9, as well as X1 (not sure what that type of component is called) are both missing. You can see the two components along the bottom side of the card in this picture: http://www.pcang.com/img/xr385_verc.jpg
Guess I get to wait several more weeks for another to get here... yay. Hopefully the seller will replace it for free, but Mau1wurf1977's experience gives me confidence that he will.
As an aside I tried it on my other CT2940 (the only other card I have, I think, that has a midi interface) and had the same issue. But now that I see those parts are broken off I'm sure the card is bad.
Good luck with that Capn', they're great when they work and I've bought three from that dude and they've all been OK.
I vowed to stop messing around with sound cards after my last misadventure (long boring story), but I had my 166MMX open the other day - which has a Roland SCC1 in it for General Midi, and a Sound Blaster (Vibra 16S) in it for FX, etc. That's all great but I have a spare XR385 hanging around and would like to be able to compare the Roland with the Yamaha from time to time, so decided to put the XR385 onto the Vibra.
I have Windows 95 installed on this machine - with which I boot to DOS 7 or whatever Win95 calls it via a DOS boot menu - so the first thing I did was boot to DOS, use Diagnose.exe to set the SB's MPU-401 port to 300 (to avoid the Roland at 330) and off I went, switching b/w 2 general MIDI devices no probs. Diagnose correctly altered my set blaster lines in autoexec.bat (which is what's called when you boot to DOS mode), hooray I said, congratulating myself for being so clever.
But, after booting into Windows 95 and then shutting down the computer, the P300 setting is mysteriously removed from my autoexec.bat, and I'm back to square one. Why would Windows do that? It's none of it's business I say, and I can't even imagine how it does it. It must be the creative drivers I'm using in Windows - do I need to setup the MPU-401 port at 300 in there too?
Yes try setting it in Windows to 300 as well! Might fix the problem.
This is one reason why I only have Dos 7 installed on my machine. I like things set, so that when I boot the machine after months of not in use everything just works.
Yes that did it, I altered the card's resources in the device manager to include the 300 IO port and Windows now leaves my autoexec.bat file alone.
It's good being able to switch so quickly b/w the Yamaha and Roland MIDI efforts. The Roland is generally "cleaner" sound to my ears, but the Yamaha is sometimes "cooler" 😀
