Reply 80 of 119, by Tetrium
- l33t++
wrote:I'm adding manufacturer, AGP support (at least one board in the list does not have an AGP port) and number of PCI slots. Is there anything else that should be there?
I'd prefer not to add too many separate lists, as this would make the list very chaotic and much harder to use when every little exception get it's own list.
In this case maybe a table which can be sorted may be of more practical use?
And be careful you don't overwrite a newer version of the list with an older version you yourself updated, that would make things a mess 😜
