Reply 80 of 283, by snufkin
LocalBus wrote on 2022-02-01, 17:00:Here goes, out of necessity I needed to lift it 😀
So looking up the datasheet for the D27C010, pin 1 is a 12V programming pin, so should be at 5V unless you want to make it possible to program the chip. Hopefully others can use that BIOS dump. I did notice the string 2A5ULT40 in it, which led here: https://loyalp.tripod.com/tonym/numbers.htm, which gives it as an "Opti 82C822/571/572 Chipset (Pentium based m/b)" "2A5ULT40: Taken (model: ???) ", so looks like Taken is correct.
Looking forward to seeing what Jan says about it.
