First post, by RiverBoa
I picked up a Magma expansion chassis that has two PCI slots and a PCMCIA adapter to hook it up to a laptop. I'm connecting it to a Toshiba Libretto 110CT because I saw it online somewhere else and someone had some success with it and a Voodoo2.
The problem I'm running into is that the computer has no problem recognizing the two cards being installed, but they both have a yellow exclamation mark next to them in the Device Manager because of a Code 12, no available memory range.
The Libretto 110CT uses a MagicGraph onboard, and the only other devices in device manager under memory are the CardBUS adapter and ACPI. The MagicGraph uses quite a few memory ranges, which is probably normal.
Anyone have a clue on how to resolve the memory range issue? I don't have an option to turn off ACPI in BIOS, although I think I might be able to with a registry entry.
