First post, by DevilTenchi
I've identified some components on this motherboard that need to be replaced. I can solder just fine, but I'm not good at figuring out data sheets. Can I please get some help identifying a modern transistor replacement and what the other part is? Parts went up in smoke testing a CPU in 3V mode, now marked as bad. Now board will not post. Transistor now tests as a short.
Parts to replace
CPU Power Transistor - HSMC BU406B
Part that is in the same circuit, looks like a green resistor. - (Color Bands left to right) R BL BL R R
Pic
https://drive.google.com/file/d/1BdYcfL2tiuUK … ?usp=drive_link
Thanks everyone.
