First post, by Tumerboy
I snagged one of the Pocket386's off AliExpress, and with it, one of the ISA8-EXP-01 expansion boards. This is a board that connects via ribbon cable to the back of the Pocket386, and then has 3x 8bit ISA slots for use with. . . whatever.
These showed up yesterday, and I have an old ISA Sound Blaster in the archives, so I was going to plug it together and see if I could get some better audio out of it.
Problem is, 8-bit ISA isn't keyed, and can be inserted either direction, and the board has no obvious marking telling me which way is which.
I'm not as experienced with this stuff as most of you, but my instinct says plugging a card in backwards might be bad. Is there some way of telling which way is which on this? There are markings at one end of each slot (You can kind of see them at the top of the picture) indicating an "A" side and a "B" side to each slot? But I'm not sure if that corresponds to something on the card?
I'd appreciate any help or insights y'all can offer. Thanks
