First post, by TonyStark
Hello all, I'm, trying to find out the brand of a tower case, It had a MHz display screen, a gray stripe on the front and a pink/fuchsia triangle power button facing downwards. It was the case from a build of a friend of mine and as I try to rebuild that PC (I remember every part) I'm trying to find that specific case. Does it ring a bell to anyone, the design I mean ?
Thank you in advance
Reply 2 of 5, by TonyStark
I'm not quite sure about the screen, but it looked similar to the one on the first picture, 2nd from left on the bottom. flat surface, no curves
Reply 3 of 5, by oh2ftu
Oh my. So many cases. And none of them is similar to what I have or have used.
I hope I'm not the only one getting a "vibe" from those similar cases that are *not* grouped together? 😁
Reply 4 of 5, by appiah4
Hijacking the thread to ask kixs do you have photos of full tower cases with front doors covering 5.25/3.5 expansions? Hunting for my first case 😅
Reply 5 of 5, by kixs
appiah4 wrote on 2024-05-06, 12:55:
Not much. Only one black with missing front cover and one IBM Xseries 220 with Dual 1.4GHz Tualatins installed.
