First post, by kaolinitedreams
I made a post a couple weeks ago about getting a hard drive up and running for my Zeos 486dx. Long story short, I tried formatting an SD Card to Fat16 many times using the dos boot disk. I would be able to partition but it would give me errors when I needed to format it OR formatting it during a Windows or DOS installation (Writing to C Drive.) Then I tried different cards, same issue. Then I tried a CF adapter as a hard drive. Same issue. All these times, I thought maybe the A Drive was having issues writing/formatting from the DOS boot disk. Someone on here suggested that perhaps that I use an era-appropriate hard drive. Voila! It worked...
The issue is that now I tried installing windows 95. I got a disk error while installing...writing to the C Drive. Similar issues, but different hard drive. Do I have a 3.5 Floppy Drive that is crap and doesn't write? I already had to replace the original FFD drive (corroded) and cable (wasn't reading the new FDD drive.) The thing is that I have used multiple hard drives, so I am leaning that it's not a hard drive issue, but writing to the drive is the issue.
*I also want to say that I have tried new IDE cables for the hard drive/motherboard, and it didn't affect anything.
Any input is greatly appreciated. Thanks!
    1.95 MiB
    1.04 MiB
    1.79 MiB
Reply 1 of 7, by Jo22
"Formatting 1,951 M"
I think the issue might be the drive geometry.
386/486 era BIOSes usually had used CHS addressing and a 1024 cylinder limit.
So maximum values that could be used in CMOS Setup were 1023 cylinders (0-1023), 16 heads (or 15, if counted 0-15), 63 sectors. That's about ~500 MB.
Some 486 BIOSes also had support for E-CHS aka LARGE.
Merely late 486 BIOSes (WinBIOS etc) had LBA support.
This issue is even more of a problem with Windows 9x, btw.
Because it has two personalities.
The DOS personality uses whatever the BIOS uses.
The graphical part, though, uses a hsrd disk driver, which tries to determine real HDD drive geometry by asking the HDD itself (ATA command).
If two sides are different, data corruption and read/write errors may happen.
Ideally, Windows 9x realizes this and uses DOS as a HDD driver (HDD is being reported to be run in 16-Bit compatibility mode).
That being said, I think that the DOS side also had issues with the HDD parameters entered in CMOS Setup to begin with.
Probably it wasn't noticeable first, because the DOS installation was very small and didn't exceed the 1024 cylinder limit.
The partition size of 2GB as such is no issues. DOS can have four of those, I think. So up to 8 GB of storage capacity can be used fine.
It's just that the BIOS needs to support E-CHS or LBA.
It's not enough that the CMOS Setup let's someone enter certain values, the BIOS has to support them, too.
The CMOS Setup Utility is just a front-end, however, it doesn't know the actual limits of the BIOS.
Edit: To fix the issue, a Dynamic Drive Overlay (DDO) can be used. Like EZ-Drive.
It installs onto the hard disk in the boot sector and will make 286/386/486 PCs handle big HDDs.
Alternatively, XTIDE Universal BIOS can be used. It can be be burnt into an ROM chip.
A network card with a boot socket can then load the ROM during booting.
Edited.
Reply 2 of 7, by Horun
Yes ! What size real hard drives and what size CF have you tried ? Anything 512Mb or less should be ok no matter the 486 board/bios.
Reply 3 of 7, by kaolinitedreams
Horun wrote on 2024-05-12, 23:50:
I have tried multiple sizes - 250mb, 425mb, 512mb, 1.9gb, 800mb....all do the same things. On the SD Card it was 425, 512, and 2gb. On the CF it was 1.9gb. On this current hard drive that crashed with the win95 installation, it was 250mb.
Reply 4 of 7, by Jo22
kaolinitedreams wrote on 2024-05-13, 00:04:
It could be a related incompatibility, still. 286/386 and early 486 BIOSes did pre-date ATA-2 specification.
ATA-2 did change some subtle things, which caused all sorts of little issues.
In my case, it did hang a 286 PC during boot with a BIOS dated 1988.
Using XTIDE Universal BIOS on a network card fixed all issues. The electronics remained same.
So installing a DDO to HDD (easy to do, via setup floppy) or XTIDE Universal BIOS should should fix that as a side effect.
Phil's Computer Lab site has a collection of DDOs, I remember.
Trying them out doesn't cost anything, except a bit of free time. :)
Reply 5 of 7, by kaolinitedreams
[/quote]
Trying them out doesn't cost anything, except a bit of free time. 😀
[/quote]
I'm not familiar with DDOs or XTIDE Universal BIOS (I'm still very much a newbie), but I will look into this. Thank you!
Reply 6 of 7, by Horun
DDO + Dynamic Drive Overlay. Was a common way back then to allow use of a larger/newer HD than system supported. DrivePro, EzDrive, Disk Manager, MaxBlast...etc
Seems Phils page is down (blank) but here are some: http://www.vogonsdrivers.com/index.php?catid= … menustate=68,66
and some others: https://ia803408.us.archive.org/view_archive. … %20Hd_utils.zip
read any included TXT files before using any one of them. Generally you set your BIOS to drive type 1 (no matter what HD), save exit and install the DDO from floppy.
How they work is same but is sorta specific to each type.
Reply 7 of 7, by kingcake
Horun wrote on 2024-05-13, 01:05:
DDO + Dynamic Drive Overlay. Was a common way back then to allow use of a larger/newer HD than system supported. DrivePro, EzDri […]
The last time I used OnTrack 9.57 I'm pretty sure it said to set BIOS to Type 22.
