First post, by Kubik
Folks,
what kind of DRAM card goes to Toshiba T1910 / T1950 (and other Toshiba 486) laptops? Some sources say it's a proprietary card, while some others suggest it's a regular PCMCIA / JEIDA DRAM card. Also, if it is the later, which one? There are, according to Wiki, various versions, different number of pins, and even the ones with same number of pins (V1 and V2) are said to be incompatible.
https://en.wikipedia.org/wiki/JEIDA_memory_card
I have fixed T1910 and T1950 (leaky caps) and they work fine, but they share one 4MB DRAM card which isn't great.
I can see some PCMCIA DRAM cards here and there, but it's not clear which ones are compatible.
Thanks a lot!
