First post, by dadocastro2801
I recently managed to make the floppy drive of an amstrad work and transfered the system files to a CF on a XT-CF card lite rev 4.1,
the problem is that the amstrad denies to boot from it but it recognizes the disk booted in msdos from a floppy.
I have tried using fdisk to create the partition, format C: /S, sys C:, copying the files to the root and to a DOS folder and copying command.com manually.
any ideas?
thanks
