Reply 44900 of 57151, by ChrisK
BetaC wrote on 2022-05-31, 23:27:So I now own $18 worth of gold. And it’s at 60MHz. FD09D0F5-2A71-441C-805E-46504D1AFADE.jpeg
Question is, how do I get this heat sink off without also losing the text on top?
That's a nice and really rare PPGA P60 (one without golden heatspreader). Just seen them once (in my collection, hehe).
Mine had the same cooler mounted on top. It had a doubled sided heatpad that was quite resistant but luckily only adhered partially to the CPU.
I was able to remove it by soaking it with isopropyl alcohol and working around with some small wooden wedge after some time. The pad eventually gave up under this pressure after some time, luckily without damaging the print and without leaving scratches or anything on the ceramic.
Others here prefer some freezer method but this wedge method worked for me.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
