Reply 47120 of 47936, by Horun
- l33t
smtkr wrote on 2022-11-25, 01:17:TrashPanda wrote on 2022-11-24, 06:26:Grabbed this Celeron 300A, Abit BH6, 128MB + TnT2 setup for a good price from a local seller here in Australia, seller confirms this Celeron runs stable at 450Mhz @ 100 FSB, going to use this board to see if there is much if any difference between the Slot 1 300A and the S370 300A, got a nice Celeron Slotket ready to go.
Its a nice bit of kit which Ill likely keep for future build.
The one tough thing about these Abit boards is the location of the ATX connector. I wanted to use a modern PSU with a 24-pin connector on mine and realized the 4 extra pins hang off in front of the AGP port. Luckily I have an old PSU from the era that I can use.
Yeah one of the few bad designed Abits. All that space between ram and cpu where the ATX connector should have been (is all that V+ or Gnd plane visible just for looks ?) . Get a short 24pin to 20 pin adapter.....
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor.
