Reply 49480 of 57170, by Trashbytes
- Oldbie
Bought a Quadro M4000 for a future build I am working on, its roughly equivalent to a GTX970 but with 8Gb of Vram and a single slot design. Also found Windows XP drivers for it .. not sure how XP will handle 8Gb of VRam but itll be damn amusing seeing the GPU have as much memory as the main system does !
I did want a more powerful card for this build but the 980ti and Titan X are still in silly price territory for secondhand cards and this Quadro was 150 bucks AUD (~100 Freedom Dollars). It also maintains XP compatibility which I also wanted as the build will be using a 4 bay hot swap SSD setup to run multiple setups with XP32 being one of them.
Might also look at the Quadro M6000 as a Titan X replacement if the prices remain stupid, the M6000 goes for ~230 AUD right now which is about half the cost of a Titan X at ~500 AUD ..the Quadro also has a 24Gb version which would be even more amusing under XP.
And yeah I know they are not really gaming cards but will no doubt still be able to run anything from the late XP period with little issue.
On a different note I ran across this little nugget of a CPU a Athlon 64 X2 6400+ BE ADX6400IAA6CZ for ~100AUD (~66 USD) and just had to have it, at this price its worth grabbing as they generally go for a lot more and are rather rare. Got just the rig for it too, itll be a nice upgrade for the A64 5000+ 6CS model in it.
