Reply 5520 of 52832, by MrTentacleGuy
I just picked up a Packard Bell Platinum 55 for $10. I had recently bought the monitor with speakers for $5 and the keyboard and mouse for around $10, so $25 isn't bad for a complete Packard Bell. It has a 200Mhz processor, two 2GB HDs, 48MB of ram and a Sound Galaxy sound card.
Reply 5521 of 52832, by PhilsComputerLab
retrofanatic wrote:
AlphaWing wrote:
Good luck with that x-fi! I had that same oem x-fi card in my main PC for awhile, gave up on it, due to clicking sounds being in […]
I had that same oem x-fi card in my main PC for awhile, gave up on it, due to clicking sounds being inserted into just about anything played over it, issues with the drivers in windows Vista and 8, worked fine in XP, but that PC rarely boots into XP.
As for I/O plates I just make them outa malleable Plastic, usually cut from Ice cream buckets, and paint them whatever color, and attach them either with glue or nuts\bolts if the case has convenient holes to mount with. Usually ends up looking nice, and easy to cut every hole needed, with no sharp edges.
Cheap and easy solution that comes with a treat 🤣 .
🤣...yeah I heard that these xfi cards can be troublesome but I only plan to use it on xp anyways. I have a retail pci e Creative card for my win 7 setup.
I love the idea of using plastic from buckets or whatever works. I tried using acrylic once and it worked pretty good. Easy to cut with olfa knife so it is easy to work with but I like your idea about the malleable plastic. ..I think it would be easier and cheaper.
I looked and it's a 670, that's the card that works with the stock Creative drivers.
YouTube, Facebook, Website
Reply 5522 of 52832, by ODwilly
Posting from my new Thinkpad 770. 233mmx Pentium, 2mb Trident, some crystal based audio chip, 4.7gb hard drive running Windows2k on 228mb of ram. Currently using IE6 and trying to find the best version of Firefox to download. Spent all day yesterday scrubbing it with Simple Green, it was coated in mold. O and it is missing half the paint 🤣
Reply 5523 of 52832, by smeezekitty
Don't bother with firefox with 228MB RAM.
I suggest you try Opera. Somewhere between version 9 and 12 works good on old systems
Reply 5524 of 52832, by ODwilly
Ya it is a little sluggish on Firefox 12 or whatever version it is I ended up istalling. Time to scope out Opera and I am trying to figure out the best way to get some form of Flash on here. Somewhere I read about a way to use VLC to play youtube videos. Overall this system is not half bad on 2k, surprising for a 95 based laptop. Heck it even has a USB 1.0 port on the back!
Reply 5525 of 52832, by soviet conscript
snagged one of those serial to ps/2 converters for $9.99 so will see how well this one does once it gets here.
http://www.ebay.com/itm/111506636891?_trksid= … K%3AMEBIDX%3AIT
Reply 5526 of 52832, by JidaiGeki
Won this on eBay recently - was advertised as an AWE32, but turned out to be an SB32. Not too fussed, it's an impressive looking card 😎
Also picked up the following two (untested) cards in a big and very cheap haul of mostly Apple cables and SCSI stuff:
EDIT: Any suggestions for a good free image hosting service?
Reply 5528 of 52832, by Skyscraper
I use http://cubeupload.com/
Its free and fast.
Reply 5530 of 52832, by HighTreason
I use postimg. Though I don't doubt somebody will ruin them all eventually - just like Imageshack.
Nice, a Yamaha 724 card, neat little things those with the little XG synth... A coincidence is that I've just started unscrewing the side panel for my P2, which houses a card with that chip, I think SoundMAX made mine but I don't remember.
Reply 5532 of 52832, by sf78
Top: Asus AGP-V 3000 (Riva 128) - Diamond Viper 770 32 AGP (Riva TNT2) - Creative 3D Blaster Banshee (CT6750)
Middle: ATI Rage II + DVD - 3Dfx Banshee
Bottom: ATI Rage Pro Turbo AGP - TNT 2 32 AGP
Best part? 2e from a flea market! Last 2 were free (recycling center).
Reply 5533 of 52832, by King_Corduroy
Wow someone really decked out your system, mine came to me almost stock and I had to upgrade the CPU and RAM. Nice find though, I love my Packard Bell Platinum 55. Wish I could say I had the monitor and correct mouse but alas I do not. 😜
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 5534 of 52832, by schlang
You don't need AT cases as there are pretty good AT/ATX cable converters
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 5535 of 52832, by Artex
It's not so much the cables that are the issue since as you said, there are all kinds of converters out there. The issue is the standoff/hole arrangement for AT motherboards.
Reply 5536 of 52832, by schlang
are there really differences compared to "not so newish" ATX cases?
Reply 5537 of 52832, by Artex
Yep, the mounting holes are different. Some ATX cases have mounting holes for AT form-factor cases, however.
Reply 5538 of 52832, by schlang
Yes, since I haven't had any problems so far
