Bought a computer at a thrift store the other day.
There were several, but I picked this one as I saw it had RDRAM slots (with memory modules) and a PSU that wasn't too flimsy looking.
I was hoping for another s423 board, but I made a mistake as the board turned out to be an ASUS P4T-E, which is s478, first one I ever seen in the flesh with RDRAM slots.
All caps look fine, which isn't a guarantee though that they are but at least there isn't any cap leaking stuff on the PCB 😀
The rest of the hardware wasn't too interesting though.
Some AGP Matrox card (something G55 with I believe 32MB), a cheap-looking sound card and a simple NIC and some kind of ASUS mini-PCB which is fitted onto the bottom-most expansion bracket on the back of the case.
The HDD was still there (usually they are removed), but it's only a 40gig WD Caviar-something, but then again all harddrives are welcome afaic.
The usual stuff, a few optical drives, nothing too interesting.
I knew the PSU wasn't FSP of a particularly good brand, but I suspected it wasn't a crappy one either. Turned out to be a CWT or something.
I remember having another PSU made by CWT which I got many years ago and I remember it worked fine (can't remember what I used it for though, but at least it looked more solid then the El Cheapo air-filled ones, the CWT looked more like an FSP unit).
All 4 RDRAM slots are filled, but all modules are single sided. I haven't checked the module sizes but that's not really that important as I already have way more good-sized RDRAM modules then I have boards to put them in 🤣
And of course it has a floppy drive.
The case is a standard beige one similar to the ones that used to sell into the millions of numbers and has an ok 8cm fan opening thingy in the back. It seems to be reusable, but I'm already very well stocked on computer cases and sooner then later it will be my turn to see if I can get rid of some of the stuff I have.
I don't have a working camera anymore so no pics 🙁 and I haven't taken apart this system yet so I don't know the remaining part numbers.
I'd say this mini-haul was better then my previous one a couple months ago (many parts were either missing/incomplete, leaking caps, non-interesting parts (like GF2MX and Sempron 2400+ sA and double sided 512MB DDR-333 I think?).
Also bought a 486 HSF for only €1,50, the type that latches directly onto the CPU with 4 hooky things 😜
