RacoonRider wrote:Lukeno94 wrote:
Toshiba Satellite Pro 460CDX. It has a 166 MHz Pentium MMX CPU, but I have no idea about the chipset. It is missing a battery and HDD caddy (standard IDE connector seems to be built in at the back), and although it powers fine when no HDD is fitted, fitting one produces an orange blinking power light for some reason - any ideas?
Might be a long shot, but Toshiba Libretto 50CT does this when the HDD (in my case a CF card in adapter) is inserted the wrong way, with an offset, so that the power line of the board gets connected to ground line of the HDD. Nothing gets burnt though, I suppose some kind of protection does the job.
It wouldn't surprise me, although I thought I had inserted the drive correctly on both occasions - may try again later. If I had the caddy, that would make my life easier... but I don't, and I can't find one on eBay either. I can find 460CDXs that appear to be complete, but I don't want to spend £20 and have yet another untested laptop when I might get no return whatsoever.
I now have a HDD caddy for the Compaq Evo, which seems to work fine in Windows XP... apart from the backlight's tendency to switch itself on and off and random (or not come on fully at all). Screen is visible (barely) even when it's off, but it's a pain. It's a pretty snappy system as well, with 1GB of DDR RAM fitted. I've also swapped the screen on the Pico, upgraded it to 512MB of RAM (any higher produces weird ACPI errors when booting Windows, for some reason - even though I know both slots were good) and replaced its CMOS battery. Strangely enough, the trackpad is mounted to the main chassis, not the palmrest - never seen that approach taken before. Even weirder is that the RAM is underneath the keyboard (and two metal shields below the keyboard as well), even though the CPU, CMOS battery and HDD can all be accessed from underneath the system...
Finally, I took delivery of an iBook G3 600 MHz (not a clamshell), but sadly it seems to be U/S. It was sold as having a dead HDD, which it indeed did have, but it simply won't power on for more than a second - spins up a good HDD, but only briefly and goes no further. Ah well, will try stripping it down and inspecting it at some point, and maybe replace the motherboard.
