Reply 13120 of 52944, by Brickpad
- Member
wrote:wrote:Looks to be the PCChips M915 also known as the Amptron DX9200. I've got the same board, but the ISA slots are white and "Fugu Tech" stickers on the chipset (yeah, right). The lack of an onboard FDD is rather annoying too.
Yeah I was searching TH99 and came to the same conclusion.
However since it doesn't have serial/parallel ports either it looks like one of the ISA slots will go to an IO card anyway. Just have to make sure I find one that won't conflict with the onboard IDE ports. Can you disable or change resources for those in BIOS?
Haven't used the board in a while, so I can't tell you for certain. I'm pretty sure you can disable the onboard IDE controllers though.
